News
Hep needed: Fuel pump..Capacitor? Fused Link?
Discussion in 'Technical Q&A' started by PeterS, Jul 31, 2004.
  1. PeterS
    PeterS Three Time F1 World Champ
    39,625
    95370
    PeterS
    #1 PeterS, Jul 31, 2004
    Please help me ID the black part on the top of the pic. My guess it's some sort of fused link. The wire on this broke and I bought a fused link at Napa, the grey one on the bottom.
    Are these the same? If not, what is the black unit? The fuel pump does run without this.
  3. dm_n_stuff
    dm_n_stuff Global Moderator
    Global Moderator Lifetime Rossa Owner
    Dec 10, 2003
    36,596
    The Sunshine State
    Dave
    Looks like a resistor or capacitor. What numbers are on it? Can you get a close up of it, with all of the numbers showing?
    What car did it come off of?
    Have you checked the wiring diagram? IT will indicate what it is with a symbol.
  4. PeterS
    39,625
    95370
    PeterS
    The only thing on it is 2.2pF, 110V
  5. Rifledriver
    Rifledriver Two Time F1 World Champ
    27,086
    Austin TX
    It was originally installed on carb cars for radio suppression. You are not the first one that, that has happened to. The pump should run fine without it.
  6. Steve Magnusson
    Steve Magnusson F1 World Champ
    19,900
    Texas
    It's a capacitor (2.2 pF is the capacitance rating of 2.2 pico-Farads and the 110V is the breakdown voltage that it can withstand). It might also help reduce arcing of the motor brushes on the stock-style (i.e., rotary vane driven by a brush-type motor) fuel pump.
    Don't install the fusible link as a replacement -- it will just blow (or cause the fuse in the dash to blow if the fusible link has a higher current rating) since you'd be hooking it from +12V to ground.
  8. PeterS
    39,625
    95370
    PeterS
    Thanks for the replies. I soldered a new lug to the capacitor and re-installed it.
