Here's a pic of me pulling the engine out of my 612 yesterday! | Page 13 | FerrariChat
Discussion in '612/599' started by trygve11, Jul 4, 2014.
  1. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,949
    The Cold North
    Tom
    Maybe I do things wrong, but all I do, to tighten the cam sprocket, put the belt on, set your timing, tension the belt, then I have an assistant hold the crank while I torque the sprocket. Rotate the engine around a few times, check your timing etc. Never ever failed to work, nor ever had a problem. Trying to tighten that sprocket without a belt on it, or some kind of holder is indeed asking for trouble.
    Sorry about your luck. I'm sure you will fix it and have a beautiful car to drive. Enjoy!!
  2. fatbillybob
    Aug 10, 2002
    28,993
    socal
    Well Howie your method works if you have an assistant and if the belts can take the torque. Great to know they can. I'm not a trained mechanic so errr on my idea of caution keeping force off the belt. Your method is faster and safer since you can't make a mistake leaving a cover in a cap if there was never one in there in the first place.
  3. SWBTom
    SWBTom Rookie
    May 26, 2008
    6
    NW Ohio
    Tom Bryant
    Great thread. I'll be following along to the end result.
    Tom
  4. 134282
    134282 Four Time F1 World Champ
    40,647
    California
    Carbon McCoy
    LOL!
    Chris, can you please tell me the serial number of your 599? I believe it's the only one of your Ferraris not properly documented in my database. Thank you.
  5. flxzcat
    flxzcat Karting
    Sep 16, 2008
    143
    lake forest, ca.
    paul van der linden
    Using the match book cover method couldn't that permanently distort the caps?
    Or am I misunderstanding the technique?
    Cheers, Paul
  6. trygve11
    trygve11 Formula Junior
    740
    Kansas City
    Jason Hagen
    I like the idea of the razor blade cover material. That way I can slit my wrists will all the razor blades if I F-this up a second time! But seriously, I intend to use this method.
    I don't like the T-belt in place method though that is what I used for the 7-12 cylinder bank (which turned out fine). The problem I had on the (right hand) 1-6 cylinder bank is that I had to pull the tensioner off to rebuild it and didn't have a belt on at the time I did the final torque of the cam wheels. That was my mistake. I tried putting a clamp between the two cam wheels but it didn't hold when I hit the bolt with the impact.
    I will have the head off tomorrow. My valves, gaskets and other parts (including my new 599 Challenge rims!) are arriving this week from Europe. I plan to have the head ready for re-installation for Thanksgiving weekend.
  7. trygve11
    740
    Kansas City
    Jason Hagen
    #307 trygve11, Nov 15, 2014
    OK, head pulled successfully today. As expected, two bent exhaust valves on cylinder #6. Way bent! And little kiss marks on the piston (but surface level only, no indentation, just two bright crescents into the otherwise matt perimeter area).
    So, off the the machine shop to have the two exhaust valves installed and then a much more careful approach to tightening the cam wheels.
    Funny I've never screwed up a timing belt install until now. Got rushed and stuck with no help at the time. That'll learn me!
    And head gasket still looks like new but I guess I've got to throw a new $200 gasket on. Ughh!
  8. Schestc2
    Schestc2 Karting
    Sep 20, 2012
    175
    Vienna, Austria
    Stefan
    What a great spirit - sure your Scal will be so much closer to your hard when its up and running than a "just bought" Ferrari! Had similar experience with some of the bikes I build up from scratch when I was young(er).
    All the best from Europe,
    Stefan
  9. trygve11
    740
    Kansas City
    Jason Hagen
    Thanks Stefan!
  10. tazandjan
    39,166
    Hang in there. That is a pretty small mistake considering how much you tackled. Did not think it would take you long to remedy and everything is easier the second time around. Especially so since you did not have to pull the engine again. There is a locking tool for locking the crank, but the WSMs just show ViceGrips for holding the cams in place.
  11. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    Jason,
    While your intake is off, you may want to get the new 612 hose kit from Scuderia Rampante.
    This is a brand new kit to deal with the rubber 180 hose failure.
    Cheers,
    Shiv
  12. Matt74
    Matt74 Karting
    Oct 23, 2014
    160
    South of France
    Oh my, Huge & total respect to you.
    This is the best thread. Ever.
  13. trygve11
    740
    Kansas City
    Jason Hagen
    #313 trygve11, Nov 16, 2014
    OK, I looked at your prioe forum thread on this but couldn't find any non-OEM alternatives. So, for now I've added the OEM part to my upcoming order. Thanks Shiv.
  14. tazandjan
    39,166
    Dave and crew at Scuderia Rampante Innovations were just putting the finishing touches on that pipe to replace the hose last time I heard. Probably worth a call.
  15. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    #315 m5shiv, Nov 16, 2014
  16. tazandjan
    39,166
    Looks a lot sturdier than the 180 deg bend in the rubber hose.
  17. jvecchi
    jvecchi Formula Junior
    May 5, 2005
    370
    Sarver, PA
    John M. Vecchi
    Does anyone know if they are coming out with a similar kit for the 599?
  18. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    I haven't seen the 599 motor close up..but I had a very close look at the F12...there are no more rubber hoses in the valley. The new design is very clean in this regard.
    I'm sure Taz will fill us in.
  19. tazandjan
    39,166
    #319 tazandjan, Nov 16, 2014
  20. trygve11
    740
    Kansas City
    Jason Hagen
    OK, parts are in! Head has been repaired and is ready for install tomorrow!
    Also, my 599 Challenge rims arrived and I've ordered my Michelin PSS tires.
    Stay tuned for updates over the next few days!
  21. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    Hope all goes well!
  22. trygve11
    740
    Kansas City
    Jason Hagen
    If you ever think you are having a lot of bad "car luck", well welcome to my world...
    I put the "repaired" head in today. And then did a leak down before moving too far past just flat head install. Well, turns out my intake valves must be bad (not just my exhaust) on cylinder #6.
    So, head comes back off tomorrow and goes back to machine shop. I wish the guy would actually do his job right and check the whole head and not just the valves that had an obvious bend.
    So... another $500 investment coming and a few more days wasted...
    Ugh!
  23. Piper
    Piper Two Time F1 World Champ
    Jun 6, 2010
    25,415
    Northern Virginia
    Bob
    Sorry man.
  24. trygve11
    740
    Kansas City
    Jason Hagen
    Yeah, it must be starting to sound like I don't know what the hell I am doing...
    But... in actuality, I learning some good lessons in inspection and patience. Stupid of me to expect that the machine shop would have checked the head for vacuum, right?! I should have sprayed fluid into the ports to see if any flowed through, etc. before putting the head back on.
    Well, whatever doesn't kill you (or make you completely crazy), makes you stronger. This timing mistake has obviously cost me a lot of time and about a grand, but at the end of the day the car will be solid... by this Spring!
    So, will attempt again in two weeks.
    - Jason
  25. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    and another headgasket? sorry to hear!
