Here's a pic of me pulling the engine out of my 612 yesterday! | Page 15 | FerrariChat
Discussion in '612/599' started by trygve11, Jul 4, 2014.
  1. rmmcdaniel
    rmmcdaniel Formula Junior
    262
    Jason - Like many on here I am fortunate enough to fall into the category of "having everything" (all things relative, I have what matters: health, family, and means...although I do not have an F car, yet!) and tell my family to not get any holiday gifts for me and spending time with them is gift enough.
    I woke up early this AM with fam still asleep and picked up the iPad to read newspapers feeling truly blessed and at peace. I started scanning F chat and only tapped on this thread as there were few new posts / traffic on other threads and I wondered why this "pic of a pulled 612 moto" kept appearing at the top of the forum.
    Two hours later I feel like Santa is real (his name is Jason) and finding this thread is my gift! I am truly in awe of your knowledge, commitment and passion to this project. Thank you so much for sharing this experience with all of us. I wish you all the best in bringing it to completion and will be following to the end.
    Also, much respect for sharing your honest insights and thought process as you work thru the few challenges you have faced. You clearly have extremely high emotional intelligence in addition to your engineering prowess. Please keep sharing and continue to ignore the ignorant few who post on here.
    Cheers!
    PS - once you finish if you ever have the car up in Chicago please let us know as I am sure there are many of us that would love to meet you and check out this beauty.
  2. trygve11
    trygve11 Formula Junior
    740
    Kansas City
    Jason Hagen
    Thank you for your encouragement! There is a very good chance the car will be living in Chicago when it is completed so you will definitely be able to check it out. What part of town are you in? My new job is in the loop and we will likely be relocating to Chicago in the next year or two.
    - Jason
  3. rmmcdaniel
    262
    I work in loop and live in Gold Coast.
  4. since-15
    since-15 Formula 3
    Nov 26, 2008
    1,142
    GREAT THREAD!! This is a journey and it epitomizes the saying "nothing ventured, nothing gained." Sorry for the pitfalls but you will obviously overcome them. Looking forward to reading what the New Year brings for this project.
  5. southnc
    southnc Formula 3
    Dec 25, 2013
    1,765
    Charlotte, NC
    Adam
    When you finally succeed, you'll be our new resident expert on the 612. :)
    Best of luck.
  6. ferry430
    ferry430 Formula Junior
    Oct 21, 2012
    264
    Bavaria
    Andrew
    Jason, very impressing what you are doing +++
    and you will finish the car!!!
    Good luck
    Andrew
  7. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    It is very likely something so damn simple that you just cannot see it :).
    I though cannot understand what is going on here. You cannot have bent the valves again because minus the cams she passes the leak down test. You install the cams and then you have a leak issue ... hmmm??
    Is the leak issue on the same cylinder that suffered the hydraulic'ing? I'm thinking cam followers are your issue and it was not only the conrod that suffered from that experience but also one or more cam followers.
    Have you tried for the sake of testing swapping the cam followers on the cylinders that leaks to another cylinder to see if the leak moves also?
    Pete
  8. trygve11
    740
    Kansas City
    Jason Hagen
    I work in the Loop and live in Kansas City! But will ultimately need to move to Chicago and am looking at Glenview and/or close North Shore. We should grab lunch sometime.
  9. trygve11
    740
    Kansas City
    Jason Hagen
    OK, a good news update!
    After messing around chronically with leakdown tests and over-thinking everything since making that bent valve mistake, I finally discerned that the primary leakdown deltas are not valve related but a function of having rings that need to be worn in to the honed cylinders, etc.
    So, I rechecked all leakdowns on all cylinders (both banks). The results were all over the place this time with little to no leakage past the valves. And all valves (intake ones that I was able to fill with brake clean) held the fluid at TDC.
    So I decided to press on, install valve covers, seal things up and do compression check.
    Voila! 210 PSI on the cylinder that I had bent the valves on previously. That puts all my compression readings (despite still breaking in the motor) at 190 PSI or more.
    I believe I now have a "good engine" that is ready to run. Over the next couple days I will put on the exhaust manifolds and get the upper plenum installed and everything ready to run (minus the rest of the exhaust system). I hope to do a test start prior to the 5th of Jan.
    Stay tuned!
  10. jvecchi
    jvecchi Formula Junior
    May 5, 2005
    370
    Sarver, PA
    John M. Vecchi
    Excellent!
  11. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    16,969
    Wellington, FL
    Duane
    Great news! Please continue to keep posting your progress...
  12. rbf41000
    rbf41000 Formula Junior
    Nov 21, 2005
    698
    Delray Beach FL
    Russell
    Been following this from the start.
    Very impressed with your capabilities but more so with your attitude.
    I suspect 2015 will be a fun and rewarding year for you both Ferrari wise and generally.
  13. tazandjan
    39,191
    Jason- Very glad to hear everything sounds better. Just button her up and you should be making music soon.
  14. NYC Fred
    NYC Fred F1 World Champ
    16,247
    Fort Lauderdale, FL
    Fred C
    Persistence pays off.
    You're gonna have a fun spring with that car...
  15. trygve11
    740
    Kansas City
    Jason Hagen
    Thanks guys!
    After getting her running (well), I plan to run it for 30 minutes and then change oil and filters. Then run again and then install exhaust and put the rest of the bits back on the car. I have the front bumper to put back on, AC to charge and rear radar detector to mount. Then I have to get the new windshield put in, the exterior cleaned up by a touch-up specialist, then start enjoying!
    I am traveling all week long now-a-days so I plan to finish up the details over the next 6 - 8 weeks and have her ready for plates and fun my mid-March.
    Keeping my fingers crossed!
    Will post more pics as applicable. For now it's just been more of the same engine rebuild pics so nothing too interesting...
    - Jason
  16. Bisonte
    Bisonte F1 Veteran
    8,705
    Northern Virginia
    Greg
    I just read this whole thread. Thanks for taking the time to share this awesome project, and I can't wait to see the car back together. Good luck with the rest of the assembly!
    Oh, and what happened to the windshield? I heard you mention it during the restart video, but I didn't catch what the problem was.
  17. ferry430
    Oct 21, 2012
    264
    Bavaria
    Andrew
    Very good news +++
  18. Piper
    Piper Two Time F1 World Champ
    Jun 6, 2010
    25,415
    Northern Virginia
    Bob
    I just keep thinking how lucky this 612 is to have found a new lease on life.
  19. trygve11
    740
    Kansas City
    Jason Hagen
    On the windshield question... I broke it! The mirror attachment plug (metal thing that holds it on the windshield) was off when I bought the car (due to Florida heat I believe). I called the ferrari dealer to try to get a new slug (with the special thin epoxy like double sided tape like thing) to re-attach. They couldn't help me. So I used the old school glue to re-attach it. DON"T EVER DO THIS! I finally reattached the mirror and then hit it with my head when working on the dash and interior. The mirror broke off the windshield, took a piece of glass with it upon detachment, and send an 18" crack across! I then promptly filled my pants. The good news is I have $0 comp on my insurance and the new $4k windshield will be fully covered. Phew!
    As far as progress today, I spent a little time on it. The engine is fully prepped minus the upper (red) intake plenum. I've got 3 friend meeting me at 10am to lower that puppy on the motor. It will hopefully then be just a couple of hours of work to finish up the intake system, fill coolant, etc and then likely attempt to start it on Sunday sometime.
  20. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Good news at last.
    Pete
  21. Smart4400
    Smart4400 Karting
    Jan 14, 2014
    50
    Good luck with the restart... Fingers crossed...
  22. Bisonte
    Bisonte F1 Veteran
    8,705
    Northern Virginia
    Greg
    Gotcha, it's great that the windshield's covered. Hope you have smooth sailing from here on out!
  23. NickKerigan
    NickKerigan Karting
    Mar 17, 2011
    165
    Oxford, UK
    Nick Kerigan
    Jason, best of luck for the restart!
    We're all rooting for you
  24. trygve11
    740
    Kansas City
    Jason Hagen
    Everything all buttoned up on top. 100%.
    Tomorrow I route the two downstream oxygen sensor wires on the passenger headers, install the starter motor heat shield, finish bleeding/filling the cooling system and jump in and turn the key.
    Keep my 612 in your prayers tonight! ;-)
  25. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    Best of luck, Jason!
