Here's a pic of me pulling the engine out of my 612 yesterday! | Page 8 | FerrariChat
Discussion in '612/599' started by trygve11, Jul 4, 2014.
  1. trygve11
    trygve11 Formula Junior
    740
    Kansas City
    Jason Hagen
    I aligned the cams perfectly. There are both rear marks and also marks at rear portion of the front cam caps (if that makes sense).
    Now that I know I've got it perfect, for the next timing belt change I will likely just mark the cam gears and do the belts without pulling the valve covers.
    In terms of why I didn't completely assemble to engine first... well, this is how I took it out! Since I was progressively pulling the engine apart on the way out (to see if perhaps it was injured in a way that would not require pulling it), I used this approach. The approach I used ultimately leaves all the wiring in the car. If I had then taken the wiring out of the car, I might have fully assembled the motor first. Quite frankly, I like doing it this way. It will all work out!
    Today I hope to put in the clutch housing, torque tube and tranny. Still waiting for one new knock sensor (which is another reason I didn't assemble the engine fully first as I could install the cooling plenum and water pump and front timing covers until I get all the knock sensors installed).
  2. Makuono
    Makuono Formula 3
    1,009
    Ricardo
    Hi!
    Any ideas on how much this engine weights? Curious since these pictures show really how it is massive!
    This thread rocks!! Please continue to share the process with us.
    Enviado do meu iPhone usando o Tapatalk
  3. tazandjan
    39,319
    The front cam marks are just assembly marks to make sure you do not bend a valve when assembling the engine. The rear scribe marks were done after the cams were degreed.
  4. cam612
    cam612 Karting
    Jul 22, 2014
    79
    As others have said, this is a fascinating thread. Thanks so much for sharing what you are doing.
  5. trygve11
    740
    Kansas City
    Jason Hagen
    #180 trygve11, Oct 2, 2014
    They were both balls on. Front and rear cam marks on all four cams.
    Well, thank you all for your appreciation of the thread! It is motivating!
    More progress today. A caste of interested parties came by to assist (as you can see). Driveline is completely installed. Enjoy the pics.
    Tomorrow I will do pesky wiring to starter and to front of motor. My last knock sensor is in my mailbox so I can install that and install the water plenum and pump and then all the front timing covers. Then accessories. Then AC, radiators, cooling, oil. Then pause for prayer. Then turn key...
    Well, I will crank the motor with no fuel pump connections and no spark plugs to get the oil fully primed and everything lubed. Then plugs, then coil packs, then upper intake and plenum. Then attempt start. I hope by next Friday it is running...
  6. crinoid
    crinoid F1 World Champ
    10,020
    LaCrinoid
    This is so rad...
  7. trygve11
    740
    Kansas City
    Jason Hagen
    #182 trygve11, Oct 3, 2014
    Couple more pics from progress today.
    Got the steering column all together with the new (unsticky) shrouds. Also put in my new pedals (the left two) from Ultimate Pedals. I had them custom designed. The dead pedal on the left and the wider brake pedal with the Ferrari prancing horse. Also installed the driver's seat today.
    Last picture shows the install of the water plenum on the top of the engine.
    I am now installing all the accessories and will soon fill the engine with oil and turn it over with no plugs and intake plenum to get it primed.
  8. tazandjan
    39,319
    Good news on the cam timing marks. Always nice to have your hard work confirmed. My rear ones were spot on, too.
  9. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,808
    Weston, MA
    Paul
    I love that mat with the blue cavallino, where did you get it?
  10. ajyiii
    ajyiii Formula Junior
    324
    Chicago
    Andrew Y
    Much respect man, I hope someday to have the knowledge to be able to wrench on my cars.
  11. trygve11
    740
    Kansas City
    Jason Hagen
    Westwind.
    Only issue is the passenger mat is not cut to OEM. It is actually a full length mat and covers up the inclined, passenger footwell area and deadpedal. Not sure if I like that or not. I will post a pic.
  12. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Looking at the design and the way the water plenum attaches to the head is interesting. Surely it would not fit if you had to skim the heads ...
    Pete
  13. NYC Fred
    NYC Fred F1 World Champ
    16,809
    Fort Lauderdale, FL
    Fred C
    Always good to have friends that know what they're doing...
    Love following the progress. Real Ferrari mechanics squat on their engines, eh?
  14. trygve11
    740
    Kansas City
    Jason Hagen
    #189 trygve11, Oct 6, 2014
    All real mechanics get up on their engines! Especially when trying manipulate those crazy wiring retainers on the rear of their V12 Ferrari heads!
    Well, more progress today. Just one pic. Timing covers on. All accessories attached (including freshly rebuilt AC compressor).
    Tomorrow the engine will be turned over with oil in it to prime it all. Then the upper intake goes on. Then we are going to start this pig! Thursday at the latest! I start my new job on Monday so I need to get this thing rolling!
  15. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    Because what better way to pull up to your new parking space?
  16. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    Promise to have a camera rolling when you turn the key for the first time!!! Ok? We want to see sleeping beauty wake up :) and be part of starting a rebuild Ferrari v12. Nice job!
  17. trygve11
    740
    Kansas City
    Jason Hagen
    Yes, but if the engine explodes I will just silently go away and not post anymore...
  18. trygve11
    740
    Kansas City
    Jason Hagen
    #193 trygve11, Oct 7, 2014
  19. trygve11
    740
    Kansas City
    Jason Hagen
    #194 trygve11, Oct 7, 2014
    Partial success! I turned over the motor today and successfully achieved priming of the oil system. After a few cranking sessions of about 10 seconds each, the oil light goes off. That means the engine is primed with oil.
    I've installed the plugs, coil packs and am heading back over tonight to put the upper plenum on. With any luck, it will run tonight. Otherwise tomorrow.
    Keeping my fingers crossed!
  20. NickKerigan
    NickKerigan Karting
    Mar 17, 2011
    165
    Oxford, UK
    Nick Kerigan
    We're all excited!
  21. southnc
    southnc Formula 3
    Dec 25, 2013
    1,765
    Charlotte, NC
    Adam
    Good luck!
  22. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    Nice! With good oil pressure and no nasty sounds only electrical issues can hold it back from breathing yet again :)
  23. George Vosburgh
    George Vosburgh F1 Rookie
    Beautiful work Jason! I never go down into the 612 section much because you really don't see threads like this down here. Is this the first total rebuild in this section?
    Your interior looks fantastic, the car will be better than new when you're done.
  24. cam612
    cam612 Karting
    Jul 22, 2014
    79
    What a moment. We are trembling with anticipation!
  25. trygve11
    740
    Kansas City
    Jason Hagen
    Didn't get far enough last night. So hoping for later today...
    These cars are crazy in terms of how little space there is to work. I made the mistake of leaving the front serpentine belt covers off and thinking I could put them on after installing the radiator and the radiator cross-member. NOPE! On this car you couldn't even do a simple serpentine belt change without removing the front bumper, radiators, and upper cross-member. So I lost a few hours last night on some rework.
    EGR's going in and will get finished up this morning. AC seems to be holding vacuum. Have a couple of O2 sensor wires and clutch position sensor wire to route and place. I will probably leave off the exhaust until after I get a successful start (so my starting video will b e real loud!).
    I'm tired... but can't wait to try this puppy out!
