HGTE Question | FerrariChat
HGTE Question
Discussion in '612/599' started by Ferrari 360 CS, Oct 17, 2009.
  1. Ferrari 360 CS
    Ferrari 360 CS F1 Veteran
    Dec 4, 2004
    6,890
    Cape Town,SA
    Jacques
    I like many here have read a few article on the HGTE kit and the improvements it makes to handling, however nothing has been written about ground clearance issues. Had a look at a 599 HGTE this a.m and the ride is much lower than the standard.
    My question for those with the HGTE kit is does the car tend to ground on really bumpy road or is this not an issue.Already I thinking that the small lip at the front of the car is looking very vulnerable due to the lower ride height..
    Anyone had any issues with the lower height?
  2. Ferrarista3
    Ferrarista3 F1 Rookie
    Oct 30, 2007
    4,595
    MC/UK
    Carlo
    All I know is that if our 599 was 1mm lower it wouldn't make it past our parking's entrance ramp.
    Nevermind 1cm...
  3. bigguy225
    bigguy225 Rookie
    Aug 19, 2009
    38
    I also would like to know as I am getting my HGTE very soon...Is there any chance it will pass over a speed bump without scraping?
  4. Sareve
    Sareve F1 Rookie
    Oct 23, 2007
    2,968
    Singapore/Melbourne
    Daniel
    My 599 already scrapes the road when I go up or down certain carpark ramps or when I approach a hill too quickly. I think 1cm should be fine, but you might want to install skid plates to protect your bumper.
  5. M-individual
    M-individual F1 Rookie
    Oct 5, 2007
    2,937
    GTO, 458C, GT3RS
    I guess I'll be staying out of car parks. I hate that scraping sound. Had it a couple of times on my F430 and this is a sound I just can't get used to.
  6. Sareve
    Sareve F1 Rookie
    Oct 23, 2007
    2,968
    Singapore/Melbourne
    Daniel
    Most car parks are fine really, you just need to remember which are the ones that you cannot use. Since 599s have more ground clearance than other exotics, as long as you see any other low slung sports car parked in a car park, you should be able to use it too.
  7. Maximus Brutus
    Maximus Brutus Karting
    Feb 27, 2004
    81
    Switzerland
    Mine used to ground often under heaving braking in the Alps. I find mine grounds less since I had the HGTE kit fitted. Less dive under braking, firmer suspension and shorter fender liners.
  8. Sareve
    Sareve F1 Rookie
    Oct 23, 2007
    2,968
    Singapore/Melbourne
    Daniel
    Great input! So the HGTE upgrade really does reduce the body roll by a significant amount?
  9. Maximus Brutus
    Feb 27, 2004
    81
    Switzerland
    Yes it does. On downhill hairpins under heavy braking, my pre-HGTE 599 would ground out fairly frequently. Not anymore.
  10. rberg32
    rberg32 Karting
    Mar 14, 2007
    245
    I had my 07 599 dropped over an inch and never had a problem.. I did have some skid plates put on, just as a precaution, but never had a scrape.
  11. YSS
    YSS Formula Junior
    Dec 15, 2005
    338
    SA
    how much lower do the HGTE springs make it? can only the springs be ordered?
    When you dropped it an inch, what springs did you use?
    Did the ride change much?
  12. Challengehauler
    Challengehauler Formula 3
    Jul 28, 2008
    1,315
    NE Connecticut
    DB
    Here's a release from earlier this year. Purchasing this kit in stages, you have to get the entire suspension upgrade.
    "The upgrades include a renewed suspension setup consisting of new more rigid springs and rear anti-roll bar as well as new calibration for the magnetorheological shock absorbers when in the sporty positions of the Manettino (SPORT and RACE positions). The handling features a better response time and a feeling of increased compactness without unduly compromising driving comfort. The car’s ride height has also been reduced and therefore the center of gravity lowered still further, which helps with the reduction of weight shift. The lowering of the center of mass combined with the new setup helps to reduce the squat and dive as well as pitch and roll, with the resulting benefit to the car’s dynamic performance.
    This setting reduces the static roll and rolling movements on the tracks as well as pitching. This gives the car faster turn-in and less under-steer effect. The car’s performance has also been improved with new tires which have been specially optimized for this package. They are characterized by a compound that helps to allow even more effective grip for better road holding combined with excellent ease of control."
  13. Challengehauler
    Jul 28, 2008
    1,315
    NE Connecticut
    DB
    The second part....
    "The front tires are fitted on modular rims with increased rigidity and a larger track. This improves axle performance which facilitates turn-in.
    These results are achieved through both mechanical and software changes: Lower suspension (10mm) New magnetorheologically controlled suspension calibration for the Manettino
    SPORT and RACE configurations More rigid suspension springs (front + 16%, rear + 10%) More rigid rear antiroll bars (diameter increased to 24.5 mm) Tires with improved compound Modular rims with reduced weight and special new design
    The kit also adds a strong styling component: the 20” modular rims with new design and finishing treatment. The rims have a forged flange to benefit weight. The design of the spokes is highlighted by a diamond surface treatment with a technical matte transparent trim called “Silver Corsa”.
    The kit comes with the complete installation manual."
  14. YSS
    YSS Formula Junior
    Dec 15, 2005
    338
    SA
    #14 YSS, Oct 21, 2009
    is there a different offset on the HGTE wheels?
    what is it?
