My 348 has an issue with its flash beam. When flashing the main beam with the light pod down, the high beam in the fog light assembly does not flash. When the lights are up the main beam in the pod flashes/ comes on. There must be a fuse or relay that is used for this but I have checked all fuses, I can find in both the luggage compartment and the foot well but all are good. Does anyone know which relay this is used by? or could it be the switch on the steering column that has gone faulty? TIA Tal
