High Compression Piston | FerrariChat
Discussion in 'Mondial' started by EddChina, Apr 13, 2015.
  1. EddChina
    EddChina Rookie
    Oct 14, 2014
    23
    Moscow
    Hello everyone.
    I have not written, but work on my Mondial continues.
    I need to buy pistons and I thinking about high compression
    What do you think about high Compression Piston?
    From superformance for example:
    Engine (General) Parts for Ferrari Mondial - Superformance
    Who knows something about it?
    - how much compression
    - сompatibility with standard ignition system
  2. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    I'm anxious to read the answers as I'm also thinking about this for my 308. I once asked Newman what he thought about it and he said he would do it as it get better toque and that's what you want.
  3. 123howie
    123howie F1 World Champ
    Jul 3, 2014
    16,017
    El Segundo CA
    Howie
    The more you work on a engine, the more you have to work on a engine.
  4. Rifledriver
    37,099
    The 8 cyl motors really respond well to more compression. I have built a lot of 2v 308s at 10:1 or so. My own 328 has 10.7:1 with Wiseco pistons and has zero problems on US pump gas.
  5. Dizengoff
    Dizengoff Formula Junior
    Nov 24, 2011
    625
    Chicago
    #5 Dizengoff, Apr 13, 2015
    I have high compression cylinders in my Mondial. 10:1 I think. I've also got ported/polished heads and I'm running weber carbs. If you've got the $$ to do it I highly recommend it. Gobs of torque. I'm also running a steel exhaust that gives a very V12 sound instead of the usual V8 tone. It's an homage to the vintage cars.
  6. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    Interesting on the 10.7:1. Any ignition or fuel enrichment modification needed to run with those pistons?
  7. Rifledriver
    37,099
    Nope. Running the advanced setting on the Microplex and so lean it is borderline passing California smog measured precat.
    Oh yea, it is bored and stroked to 3.5L
  8. EddChina
    EddChina Rookie
    Oct 14, 2014
    23
    Moscow
  9. EddChina
    EddChina Rookie
    Oct 14, 2014
    23
    Moscow
    I am also worried about the ignition system, because there(Mondial 8) is no knock sensor
  10. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    Well that's good to know. Thanks!
    using a 360 crank? it must scoot now to a point were you might be thinking of longer euro gearbox ratios unless the 328s are the same for all markets.
  11. Rifledriver
    37,099
    No, we offset ground the 328 crank and made it fit Honda racing bearings with Crower rods.
    It makes really good torque.
  12. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    Tthe crank must be strong and stout enough allowing you to do that. Any idea how much much more power it producing over the standard motor?
  13. Dizengoff
    Nov 24, 2011
    625
    Chicago
    Where's the "like" button?
  14. Rifledriver
    37,099
    No but the right pedal works pretty well.
