High flow carb airbox for 308s | FerrariChat
Discussion in '308/328' started by snj5, May 1, 2007.
  1. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #1 snj5, May 1, 2007
    This came up in another thread, and long ago in the Airbox restriction thread. I have emailed a guy in switzerland who made this cold air induction airbox using individual filters. Sharp FChat historians will also note Kermit's short air velocity stacks. He states these are easy to make and have a much improved flow - note that the box seals against the decklid.
    He says he now makes these in carbon fiber.
    Interesting, no?
  2. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Very interesting!
  3. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    I've long wanted to seal against the decklid, too, but my big concern has always been one of maintaining sealing as the engine rolls. I've never measured how much there is, but that design sure looks like less than I was anticipating. Maybe it's best with some stiff torque rod bushings...
    I sure wouldn't want to pay for such a thing in CF when I could get Al, though...!
  4. thecarreaper
    thecarreaper F1 World Champ
    18,120
    Savannah
    i like it, but i have to be the guy with the dumb questions....
    what do you do when a motor / trans mount fails and the thing dents the hood with upward pressure? one of my old 308s has 2 broken mounts on one side( happened the same time?) and the normal airbox was rubbing the engine lid, not to mention it would jam up between gears as the linkage got all tangled up.
    seems like a cool idea, i wonder if CF would insulate it better from the engine heat? :)
    vroom..
  5. walawdog
    walawdog Formula Junior
    Nov 9, 2004
    829
    Bluefield, WV
    Anthony
    Do you think that gentleman would sell me just a base plate already cut out with the carb holes? I want to use it to make my own design. Any thoughts?
  6. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    He seems very nice on the emails we have exhanged. I would imagine you could do it locally less expensively. If you want to contact him:
    http://www.garageromano.ch/
    Good luck!
  7. docweed
    docweed Formula Junior
    Dec 8, 2004
    452
    Morgantown,WV
    Chuck Stewart
    I'm puzzled. I thought (and I'm not sure where I got this idea) the air flow around the engine was from under the car upward and then sucked out the vents in the bonnet. If this is the case then wouldn't it pull air away from the carbs rather than increase the flow into the carbs. I must be incorrect but I'm sure I heard this on this board.
  8. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I think you are correct about the airflow. The Romano Airbox seals against the flat UNLOUVERED engine bonnet lid forming an enclosed airbox. It recieves outside air only from the starboard scoop into the enclosed plenum.
  9. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Hey Russ,
    Is the pictured airbox on a GT4? My 78 GTS has the snout centrally located and not swept back like in the pic. Do you know if they have one for my car?
  10. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Each one is a custom - I'd take this photo to a local fab shop with your old airbox as a pattern and individual filters and have them make one, then have it polished or powdercoated.
  11. bwassam
    bwassam Formula Junior
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    Making the bottom sheet is not very hard. Get a big piece of cardboard and lay it over the carbs. Gently tap out the pattern. Cut it out and test it for size and then transfer it to the piece of steel. After that you can do what ever you want with it.
    It's nothing fancy but it works.
    How tall are those air cleaners?
    Bob Wassam
  12. nathandarby67
    nathandarby67 F1 Veteran
    Feb 1, 2005
    8,349
    Mississippi
    Nathan
    So why not just build it with a top on the box? Other than it would keep you from looking at those pretty air filters every time you open the engine lid?
  13. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    'Cause I guess you'd basically be back to stock?
  14. 78-308gt4
    78-308gt4 Formula Junior
    May 22, 2005
    735
    Memphis, TN
    I'm guessing it's a clearance issue between the tops of the individual filter arrangement and the closed engine cover - a top wouldn't fit.
  15. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Far more interesting... Keep using the ramair from the side scoop(s) with your filtration there and run the trumpets OPEN for maximum open height above the intake.
