High idle on a 3.4T and MAF Resistance | FerrariChat
Discussion in 'Mondial' started by UsernameBob, Jun 30, 2025.
  1. UsernameBob
    UsernameBob Rookie
    Jan 21, 2025
    45
    Rob Dyer
    Hi all,
    well I am fighting a high idle issue and need to sort it for MOT and emissions test. So I have changed out the idle control valves, cleaned throttle bodies (they were very dirty) and I just cleaned the MAF. Will find out if this has worked shortly. However before I forget, the MAF resistance (we will fight the MAFs) was 361 and 362 ohms before cleaning and I had heard it should be 382. I thought I would just check them again after cleaning and now one is 383 and other is 382 ohms. So clean the MAFs before messing with adjusting them.
  2. UsernameBob
    UsernameBob Rookie
    Jan 21, 2025
    45
    Rob Dyer
    Well after all that work, the idle is still a bit dodgy, but it is better. I think I will give her a few good runs and come back to it later. However cleaning the MAFs changed the resistance and therefore definitely contributed to an improving picture.
  3. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,452
    Menlo Park, CA
    Paul Chua
    What codes are you getting from the ECU? (if any?)
  4. UsernameBob
    UsernameBob Rookie
    Jan 21, 2025
    45
    Rob Dyer
    I must confess, I have yet to figure out getting codes out. I believe it is quite easy, must go take a look in the manual. However she is running quite smooth now although one of the new cheap Chinese idle control valves seems to be twittering a lot when I turn the ignition on.
  5. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,452
    Menlo Park, CA
    Paul Chua
    it's easy. in the trunk, takes 5 minutes, this is for the 348, but for the 't' open the trunk, both ECU buttons are on there.
    You'll do a morse code thingy - let me know if you have any questions.
