high idle when engine cold | FerrariChat
Discussion in '308/328' started by rjd2, Sep 7, 2025 at 12:52 PM.
  1. rjd2
    rjd2 Karting
    Jul 28, 2016
    126
    Hi folks-as of late, my '78 carbed US spec 308 is exhibiting a very high idle recently when cold( 2000RPM). The car idled perfectly when last tuned by Evans auto; this has only come on in the last month. Once the engine is fully hot, the idle drops to a normal range. I have touched the manual choke. I asked Evans, and they mentioned a spring style thermostatic choke, similar to 1950's american cars, that may need lubricated. I haven't pulled the air cleaner yet to take a look, as I can't find this just yet. Any thoughts as to causes here? Thanks for the help!
  2. guilhem74
    guilhem74 Rookie
    Jan 9, 2025
    10
    guilhem Clerc
    From Factory it was working like this, there is a mechanism to have around 2000 rpm under 60 degreee celsius
    TheMayor likes this.
  3. TheMayor
    106,978
    Vegas baby
    The injected cars with the bi-metallic thermostat control idle about 2000-2200 RPM when cold, then settle down to about 1000. The length of time depends on the ambient temperature.
  4. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,256
    Snohomish, WA
    Eric L
    This is the fast idle device and it sits in the middle between the carbs. A cam on a bi-metal spring turns as the engine warms up until it eventually disengages and you drop to a normal idle.
    A lot of people disable it and it's strange that your started working all of a sudden. Mine was originally disabled, then re-enabled and set higher than I like. There is an adjustment screw to lower the fast idle, which is what I did. You can adjust without removing the airbox, but you should pull it to see why it started working
  5. ChevyDave
    ChevyDave Formula Junior
    Dec 21, 2019
    455
    Pacific Northwest, USA
    Dave W
    The Fast Idle Device @flyingti is referring to is this: https://www.eurospares.com/Ferrari/308/308_GTB_(1980)/PartDiagrams/011/Throttle_Control?ref=038
    I'd been suffering from a sticky throttle linkage and eventually traced the primary cause (primary, as in there were secondary causes as well) to Item #23 ("Lever") in the above-referenced diagram...which just so happens to interface with the Fast Idle Device.
    I'm currently in the process of stripping and rebuilding my carbs and given the fact that I've disabled the manual choke, I will most likely disable the Fast Idle Device as well to eliminate another potential future problem.
    - Dave
  6. Dr Tommy Cosgrove
    36,584
    Birmingham, AL
    Tommy
    I remember this being mentioned in a road test article when they were new. It was somewhat concerning to the author with a cold engine but they were told by Ferrari that it would cause no harm
