~high mileage, tracked, rental F430, pricing advice? | FerrariChat
Discussion in '360/430' started by itwizard, Jan 30, 2011.
  1. itwizard
    itwizard Karting
    May 23, 2010
    211
    I was looking at a 2008 F430 F1 the other day, had around 20k miles, has been tracked, and was previously owned by a rental company. Service records all look clean, well maintained, under warranty for a few more months. Any idea what a fair price would be on something like this? What kind of wear and tear would tracking cause on a car like this that I might be worried about.
    Asking is $120k.
  2. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,166
    Wash DC area
    Robert
    My be pushing it, but offer $110k and see what happens. If the car is well sorted and ppi is clean, buy and start enjoying!!
    I wouldn't sweat it if you miss the price buy a couple grand.
  3. andrewmr
    andrewmr Formula Junior
    Jun 7, 2005
    320
    Bucks County, PA.
    Michael
    Has been tracked can vary from driven one day to spending it's entire life on track.
    What do the brakes and rotors look like?
    How many, and how severe, off track excursions has it made?
    Depending on what you were planing on using the car and it's current condition it could be a very nice opportunity for you.
  4. GuyIncognito
    99,802
    there are so many 430's out there, I probably wouldn't bother unless I could get it for under $100k.
  5. Jason Crandall
    Jason Crandall F1 Veteran
    Mar 25, 2004
    6,375
    ATL/CHS/MIA
    Jason
    +1
    In this market you have your choice of many nice cars. When buying stuff you always have to think about selling it.
  6. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    +2
  7. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    This is a tough one. A thorough PPI would be an absolute must. Pay special attention to the brakes. New ones are incredibly expensive. Bear in mind that its history will always be a negative when selling. For that price, I think I would prefer a well cared for 05 or 06.
    Dave
  8. andrew911
    andrew911 F1 Rookie
    2,894
    Northern NJ
    Even for a deep discount, I personally woudn't buy a rental (a personal rule I have on buying used cars). If you decide to move forward, ONLY do it for a DEEP discount. You need to assume it has been abused- driven to redline max throttle on cold oil, hitting curbs, etc. Even if only 10% of renters "abuse" the car, that is lots of abuse- it will always have a lower resale and be tougher to sell, and something tells me the number is greater than 10%. These aren't $10,000 used rental Saturn Ion's here (even one of those I wouldn't buy with a rental history!)
    People can say what they want- this is my opinion only...so many other no stories cars out there to be bought.
  9. amenasce
    34,434
    Joe Mansion
    No way id buy a rental Ferrari unless it's 50% less than market value. Just ask people what they would do if they were offered a Ferrari for a day...
  10. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    The only way to know if the car has been abused is to ask them to connect the car on a SD3 or SDX and to give you the following values. It doesn't replace a PPI but the PPI doesn't replace this neither ;)
    MAX. ENGINE RPM VALUE
    MAX. SPEED VALUE
    MAX. WATER TEMPERATURE VALUE
    MAX. OIL PRESSURE VALUE
    MAX. OIL TEMPERATURE VALUE
    MAX. OUTSIDE TEMPERATURE VALUE
    LONGER TRIP
    KEY-CONTROLLED TIME
    ENGINE RUNNING TIME
    TIME WITH GEAR IN NEUTRAL
    ENGINE START-UP CYCLES
    NUMBER OF GEARSHIFTS
    ASR COUNTER ACTIVE
    Stef
  11. MikeR397
    MikeR397 Formula 3
    May 9, 2010
    1,469
    SE Michigan
    +1
  12. itwizard
    itwizard Karting
    May 23, 2010
    211
    Thanks, I'll definitely get the car hooked up to an SD3/SDX.
    I forgot to note that I was planning to use this car as a track car, and likely will put a bunch more miles on it, so the high mileage and the track usage is perfectly fine with me, not entirely certain about the rental history though, but I'm hoping the PPI/SD3 info turns out positive.
  13. tazandjan
    39,167
    You might check on the warranty, too. On many cars, commercial use will void the warranty. Not sure what Ferrari's says. They might not have been too worried about being part of a rental fleet.
    Taz
    Terry Phillips
  14. GuyIncognito
    99,802
    are you planning on using it exclusively as a track car?
    If so, a Stradale/Scuderia/Challenge car is probably a better way to go.
  15. HH11
    HH11 F1 Rookie
    3,344
    +1
    If it is going to be a track only car then the lightweight variants would probably be the better option. Although this car has the CCBs, the scud,strad,challenge cars are designed with tracking in mind.
    And again, check the brakes, the CCBs are a fortune to replace.
  16. itwizard
    itwizard Karting
    May 23, 2010
    211
    It's actually a cross between a track car and a semi daily driver/road trip car. I only really get to go to the track maybe 4 or 5 times/year, and I'd like to enjoy driving it other times as well. I test drove a Scuderia, but the thing is just so loud all the time, I can't really imagine driving that anywhere that's far away.
  17. amenasce
    34,434
    Joe Mansion
    The scuderia isnt loud unless the valves open. You can definitely hear the radio, at normal volume, when cruising on the highway at 70 mph.
    Maybe the one you drove had aftermarket parts?
  18. itwizard
    itwizard Karting
    May 23, 2010
    211
    Mm, that's possible, I didn't ask about the details, but it was at a dealership so I would have assumed the dealer would have mentioned anything that wasn't stock. He rattled off quite a list of other things. I can ask again. Do the valves only close up in sport mode at low rpms? I know on the 458 Italia, in race mode the valves are just open all the time, whereas on sport mode the thing quiets down at low throttle.
  19. alcc
    alcc Karting
    Sep 2, 2010
    183
    Santa Barbara, CA.
    +10000000
  20. SrfCity
    SrfCity F1 World Champ
    If you were to shop around hard what would the realistic price difference on this be vs. a babied lower mile car? I'll bet it's $10 - 15K. I'd much rather have the non-thrashed car. Find out what a realistic wholesale is by calling around to dealers as if you've got one to trade in based on a low mile example.
  21. MVDESQ
    MVDESQ Formula 3
    Nov 25, 2010
    1,581
    Greenwich, CT
    Matthew & Kristen V.
    As Tazandjan mentioned many manufacturers are funny about rental fleet cars. You may want to check into this car's true warranty, if any, with FNA before you even consider paying for a PPI.
    In my opinion, unless you plan on using at the track all the time and being the last owner of it, I would not buy it. The history is always going to follow the car. Remember there are tons of F430's out there as the economy was strong when they were new. Now there seems to be a glut of cars out there. Considering your needs, why buy this one unless it is well under $100k.
