News
High Octane Fuel
Discussion in 'California (Southern)' started by PatrickShim, Jul 27, 2004.
  1. PatrickShim
    PatrickShim Formula 3
    Jun 14, 2004
    1,737
    Southern California
    Patrick Shim
    What type of fuel do you guys use? Most Ferrari manuals advise the owners to use 95 Octane, but I think most people still used 91 Octane. Anyone tried 100+ Octane? Should I mix 91 with 100 to make ~50 Octane? I've heard a guy at FBH service saying that 100 Octane can cause the engine to run too rich, and create problems.
    *** New to the forum. Love this site.
  3. Kevallino
    Kevallino Formula 3
    Feb 10, 2004
    2,248
    Los Angeles
    Kevin
    Dunno what FBH tells you, but in my Euro-spec Mercedes I will do a mix of 100 octane unleaded and premium to bring the octane up, as the car will detonate particularly when its hot/AC is running. I get mine at the pump at the Unocal station right at the end of the 110/start of Arroyo Parkway in Pasadena. Mind you it is nearly $6.00 per gallon.
    I haven't used it in my F-car yet but haven't (1) had the car very long and (2) needed to.
    Here's links to SoCal locations, the main page, and the blending chart.
    Cheers
    Kevin
    http://www.osbornauto.com/racing/100locations.htm
    http://www.osbornauto.com/racing/index.html
    http://www.osbornauto.com/racing/blend.htm
  4. Jimmy540i
    Jimmy540i Formula 3
    2,450
    Los Angeles / NYC
    www.Jimmy540i.com
    I have a 55 gallon drum of 104 unleaded sitting in my garage. They are excellent.
  5. ag512bbi
    ag512bbi F1 Veteran
    Rossa Subscribed Owner
    Nov 8, 2003
    6,586
    So. Cal
    Armen
    I mix 100 with Premium for my G.T.O. it comes out to around 95 Octane. There is a 76 station on San Miguel in Newport Beach.
  6. zsnnf
    zsnnf Formula 3
    Sep 11, 2003
    1,877
    There is also a 76 car wash at LaPaz and the 5 that sells 100. A 25% mix is good for ~20rwhp in the F40.
    California Gas in general is not too good. If you have over 10-1 Compression ratio I would mix 10-20% in on a regular basis. Every 2 or 3 tank fulls will make a difference.
    A friend of mine used some in his M3 and noticed a smoother running engine with more power. Try it for yourself and see.
    Rick
  8. jonsibal
    jonsibal Karting
    May 27, 2004
    54
  9. GregD
    GregD Formula Junior
    Nov 3, 2003
    885
    California
    Greg
    FBH Service advised me of the same thing for my maserati. They said the 91 is the way to go. They had a 550 with, i believe, injector problems due to hi octane use.
