High Octane Unleaded and Leaded fuel NOW AVAILABLE FOR EVERYBODY EVERYWHERE | FerrariChat
Discussion in '456/550/575' started by 110motoring, Dec 17, 2007.
  1. 110motoring
    110motoring Rookie
    Aug 22, 2007
    35
    Los Angeles
    Jeff Faeber
    A. 100 unleaded is $9/gallon
    B. 109 unleaded is $11.50/gallon
    C. U4.2 leaded is $15/gallon
    Shipping options are handled on an individual basis, please call Jeff for info.
    We have VP Racing Fuel, which is better than any Sunoco or Conoco(76) blend of racing fuel. All information provided below can also be found on their website:
    vpracingfuels.com
    A. MS100 StreetBlaze 100. Oxygenated with ethanol, this CARB-legal fuel is specifically engineered for high-performance street cars including sport compacts, muscle cars, street rods and more. It's environmentally friendly and street legal throughout the U.S. In applications with anything from 4- to 12-cyclinders or engines equipped with a turbocharger, supercharger or nitrous oxide system (NOS), StreetBlaze 100 will generate optimum power and performance. In turbocharged or supercharged applications, it allows an increase in boost without fear of detonation. NOS users can also leverage their higher octane ratings to step up to a more powerful nitrous oxide system. Dyno tests with a turbocharged application proved StreetBlaze100 generates up to 14% more horsepower compared to premium grade 91 octane unleaded gasoline. Designed for use in cast-iron head engines with CRs up to 13:1 and aluminum head engines up to 14:1. Works well on the latest generation of electronically-controlled turbo engines. Contains no metal compounds and won't harm catalytic converters or oxygen sensors.
    • Color: Orange
    • Oxygenated: Yes
    • Motor Octane: 96
    • R+M/2: 100
    • Specific Gravity: .746 at 60° F
    B. MS109 Motorsport 109 unleaded. Produces more power than any other unleaded fuel. Recommended for higher boost applications with CRs up to 11:1 or naturally aspirated engines up to 13:1.
    • Color: Clear
    • Motor Octane: 101
    • R+M/2: 105
    • Research Octane: 109
    • Oxygenated: Yes
    • Specific Gravity: .722 at 60° F
    C. NEW! U4.2 The latest generation of VP's U4 based fuels, this fuel is a direct pour-in replacement for U4 with little to no jetting changes required - +2 main jets and +2 pilot jets at the most. Makes power equivalent to U4 with no sticky residue and a less pungent odor. U4.2 passes AMA amateur fuel rules and is perfect for club level racing, CCS, WERA and AFM. U4.2 makes up to 6% more power than pump gas.
    • Color: Blue
    • Oxygenated: Yes
    • Motor Octane: 102
    • Specific Gravity: .784 at 60° F
  2. Kevallino
    Kevallino Formula 3
    Feb 10, 2004
    2,257
    Mid-Ohio
    Kevin
    Jeff FWIW I pay less than $7.00 per gallon for 101 unleaded at the pump at the 76 station Glenarm & Arroyo Parkway in Pasadena - I run my Euro spec Mercedes on it.
    Just a price check for you re: your 100.
    Cheers
    Kev
  3. The Ape
    The Ape Formula 3
    Feb 28, 2007
    1,793
    Los Angeles
    Ape
    On the corner of Bundy and San Vicente the 76 Station has the same.
  4. 410SA
    410SA F1 Veteran
    Nov 2, 2003
    8,511
    West Coast
    A
    100 octane is available all over Phoenix at $5.99
  5. 110motoring
    110motoring Rookie
    Aug 22, 2007
    35
    Los Angeles
    Jeff Faeber
    Yes it is, but it's cheap because it's cheap gas.
    Remember: Cheap is never good and Good is never cheap.
  6. The Ape
    The Ape Formula 3
    Feb 28, 2007
    1,793
    Los Angeles
    Ape
    This is true!
  7. Shumdit
    Shumdit Formula Junior
    May 9, 2006
    335
    Greenville, SC
    Matthew B.
    Not to disagree, but PT Barnum had a good saying too! Whether your statement or his applies in this case I have no idea, just an observation. I know it's not a popular idea to possibly question a sponsor, but hopefully you might be able to explain what's inferior about the other cheaper options.
  8. dakharris
    dakharris Two Time F1 World Champ
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Cavaliere Senzatesta
    ...and 91 octane gas that my car was designed to run on is $3.50 per gallon at Costco, which is 3 times what it cost when my car was designed.
  9. Kevallino
    Kevallino Formula 3
    Feb 10, 2004
    2,257
    Mid-Ohio
    Kevin
    Well, could you elaborate a bit more? What is it about the stuff at UnionConoco (or whatever they call themselves now) that makes it "cheap", or what is it about yours that makes it "good" in comparison to theirs (and therefore worth nearly 30% more)?
    Not a knock here (pun absolutely intended) just want to be smarterer if I need to be.
    Kevin
  10. donv
    donv Two Time F1 World Champ
    26,107
    Portland, Oregon
    Don
    I'd like to know why this is in the 456/550/575 section?
    I don't think running leaded fuel would help me pass my next emissions test, and I don't believe on a modern V-12 you would get much benefit from the higher octane, or am I mistaken?
  11. 410SA
    410SA F1 Veteran
    Nov 2, 2003
    8,511
    West Coast
    A
    Modern US version cars with computerized engine management systems are designed to run flawlessly on widely available premium grade gas.
    100 or higher octane benefits older cars, especially carb cars which were designed to run higher octane fuels. The only reason for the presence of lead in fuel is to increase the octane rating, so if you can find high octane unleaded gas it is better for the air and will do well in older non computerized cars.
  12. donv
    26,107
    Portland, Oregon
    Don
    Exactly-- and last time I checked, my 456 had a computerized engine management system!
    So, again, why is this in the 456/550/575 section?
    Maybe it would do well in the Boxer...
    Actually, not to start an old debate, but my understanding was that older, carb cars, were set up with a specific fuel in mind (or whatever fuel was in the tank when the car was tuned up), and higher octane actually gives you no benefit.
    Whereas, modern computerized cars can actually detect and adjust the spark, within certain parameters, to gain some small benefit from higher octane.
  13. GENERAL LEE
    GENERAL LEE Karting
    Nov 27, 2006
    123
    Oklahoma
    #13 GENERAL LEE, Dec 19, 2007
    Nice prices, LOL! I pay $4.50 a gallon, give or take a few cents, for Citgo Racing 110 oct in two 1050hp raceboat engines, AT THE PUMP ON THE WATER. The prices you have quoted are outragious.
    Edit: We can also get Sunoco Blue 116 by the 55 gallon barrel for $7.50 a gallon.
  14. Drive550PFB
    Drive550PFB Two Time F1 World Champ
    Remember: Cheap is never good and Good is never cheap.[/QUOTE]
    Obviously, you have never been to Las Vegas. At 3:00 am, cheap can be very good.
  15. 110motoring
    110motoring Rookie
    Aug 22, 2007
    35
    Los Angeles
    Jeff Faeber
    Hahaha
  16. carguyz
    carguyz Rookie
    Jun 20, 2005
    7
    #16 carguyz, Dec 19, 2007
    I have to say if we all lived in Oklahoma im sure that our $20,000,000.00 homes would only be worth $2,000,000.00
    I dont understand why you need to beat up these guy on the boards??? They are offering a product that is far superior
    and actually available; you dont need to order and wait...
    I have a boat as well and I have never seen less then $4.50 per gallon for 89octane!!!
    I dont usually post but you people on here are ruthless!!! Give them a ***N chance!!!
    CHILL OUT!!!
  17. 360Grigiotitanio
    360Grigiotitanio Formula Junior
    May 17, 2004
    436
    Bay Area, California
    I can buy 100 octane here in Northern CA for $5.50 a gallon and blend it 1:3 with 91 octane.
