high oil temperature reading 550 | FerrariChat
Discussion in '456/550/575' started by coachi, Dec 15, 2006.
  1. coachi
    coachi Formula 3
    May 1, 2002
    2,108
    SC USA
    yesterday i serviced my 550 maranello. I changed oil and filters, then took it for a ride. Though water temperature was quite normal, oil temperature was much higher than water tempoerature and not quite to the red mark. Does anyone have any ideas why this is so? I have never noticed this abnormality before.
  2. vandevanterSH
    vandevanterSH F1 Rookie
    3,193
    AR
    Stephen Van Devanter
    Happened to me after a similar service. Check the oil level..mine was 2 qts low and the problem was corrected with the addition of oil.
  3. coachi
    coachi Formula 3
    May 1, 2002
    2,108
    SC USA
    well, the manual said to put 10 liters, i put 10 then checked level, it was too low, so I added one more, and checked, it was at minimum, just how many quarts/liters does the maranello hold? Why does the owner's manual say 10 liters? thanks for your response
  4. vandevanterSH
    3,193
    AR
    My 575 ~12.5 liters
  5. dersark_painclinic
    dersark_painclinic Formula Junior
    Mar 8, 2005
    981
    Glendale, CA
    Lazik Der Sarkissian
    This is the same problem I whent through. When you drain the oil and change two filters whitout disconecting oil lines you need 12-13 quart. That 10 quart idea do not know where it came from. One possibility if you do not change the filters, but I am not sure. The why your oil was runing hot dont know.
  6. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    What type of oil do 550/575 owner's use?
  7. coachi
    coachi Formula 3
    May 1, 2002
    2,108
    SC USA
    the manual calls for synthetic 5W40; I am using mobil1 0W40
  8. nerd
    nerd F1 Rookie
    Oct 12, 2003
    2,535
    Coronado, CA
    RSK
    Mobile 1 Extended Performance 15W50 for our high temps in AZ.
