High pitched chirp/fluttering sound - 355 | FerrariChat
Discussion in '348/355' started by TrojanFan, Nov 9, 2015.
  1. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,182
    So. CA & NV
    Peter
    Anyone have any thoughts on a potential cause of a high pitched chirp/fluttering sound that's coming from the left rear of the engine compartment? Almost sounds like it's coming from the area of the left CAT.
    CAT was replaced about 18 months ago with a Fabspeed re-core of the OME and recently tested good so I don't think it's that unless something came lose inside and is vibrating.
    Anything else in that area subject to vibration that would make a high pitched chirp/fluttering sound? My bypass valve is bad but I was hearing this after I isolated that from the mix.
  2. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Take a piece of hose and put it to your ear and move the hose around the engine compartment and try to figure out where it is coming from. They make auto stethoscopes
    but the hose will work.
  3. plugzit
    plugzit F1 Veteran
    7,785
    Redondo Beach, CA
    Bruce Bogart
    Throwout bearings sometimes chirp. Does it dechirpify (that's a scientific term) when you depress the clutch? If it does, you need to perform a dechirpification procedure (medical terminology). As a point of interest, a dechirpification procedure was first performed by Dr. Dechirp Pakra, cousin of the famous motivation doctor Deepak Chopra.
  4. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    could be DePrairie Doggin gone depuckin(Dr BS terminology)
  5. KM1959
    KM1959 Formula Junior
    Nov 12, 2014
    984
    Kevin
    Without hearing it it is nearly impossible to diagnose but I've had blown header gaskets sound like your description. Hopefully it's not a header issue.
  6. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Leak in the air injection system for the exhaust?
  7. Robbe
    Robbe Formula Junior
    622
    The Netherlands
    as there are no belts or bearings on the left rear, I would think air injection as well.
    Or maybe the airco pump belt, which sits on the front left, but the sound travels to the back?
    The air injection system travels all the way to the right rear, but has not too many connection points on the left. So best start there.
  8. watkinsgt
    watkinsgt Karting
    Feb 4, 2008
    215
    My flutter sounded like it was immediately behind my left shoulder. Never could track it down and of course the car never exhibited the symptom at the dealership. However, as a precaution I replaced the OEM headers with stainless and haven't heard it since. So maybe a header gasket.
  9. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,628
    San Carlos, CA
    Mitchell Le
    Get a hose, stick it in your ear, go fish.
  10. Shorn355
    Shorn355 F1 Veteran
    6,859
    Colorado
    Scott
    Are you running the stock muffler? Mine had what seems comparable to the sound you are describing and it was the factory muffler starting to delaminate. Only occurred at certain RPMs but unfortunately right at the RPM for parking/maneuvering and dawdling in traffic so a bit embarassing and annoying. Replaced factory muffler with Capristo and sound is gone.
    Just something to check out - Good luck - Cheers :)
  11. TrojanFan
    Nov 17, 2008
    5,182
    So. CA & NV
    Peter
    Stock exhaust except for the CATS. Before I replaced the CATS, one of them was completely blown out. There may be parts left in the muffler that are vibrating.
  12. Shorn355
    Shorn355 F1 Veteran
    6,859
    Colorado
    Scott
    That was exactly what the FoD guys found when they stethed it so might be your culprit. I would have someone (or you) steth it and see. New factory muffler slightly cheaper than Capristo but weighs a lot more and IMHO does not sound as good. Tubi also the normal option but like the Capristo better on the 355 - Tubi a bit high-end pitch for me. All a matter of preference though.
    If is is indeed the original muffler I imagine it is or will be soon delaminating so probably something to budget for even if it is not the source of your annoying noise.
    Cheers and good luck :)
