High pressure in gearbox F430 | FerrariChat
Discussion in '360/430' started by clk20000, May 16, 2018.
  1. clk20000
    clk20000 Rookie
    Dec 8, 2012
    13
    Hello Friends:
    Recently I renew heat exchanger (oil of gearbox / water), when I change oil the gearbox I discover that it has high pressure inside, Does any know if it normal? Has the gearfox any part to purge this pressure? I think it can be this part stuck
    waiting for news
  2. mtradwan
    mtradwan Rookie
    Feb 19, 2017
    6
    pressure in the actual gearbox or the F1 system?
    if its the gearbox, there is a valve on the top of the gearbox that releases pressure and expansion from gear box, I think it might be damaged or dirty, I've seen damaged valve from it getting banged when doing a clutch job.
