HIGH TEMPS... assistance | FerrariChat
Discussion in '348/355' started by FlyingAces, Jul 22, 2011.
  1. FlyingAces
    FlyingAces Formula Junior
    Jun 2, 2011
    849
    LA 2 Vegas
    Joejoe
    #1 FlyingAces, Jul 22, 2011
    Hey guys my 95 spider is running kinda high on the temp. Only when im in traffic do I notice the temp creep up to almost red. As soon as I start cruising the temps fall to a more peace of mind 170. Any ideas on where I can start. The coolants we're checked and are normal.
  2. FerrariDeeJay
    FerrariDeeJay Formula Junior
    Jun 2, 2009
    418
    Chino, CA
    Michael
    My guess is your 355 has a fan that is not working. Stand outside each side of the car and see if both right and left fans are blowing air from the door duct. I would not recommend driving the car until you figure out what the problem is. Good luck.
  3. Future ferrari collector
    Oct 12, 2006
    1,795
    I'll say the same. I blew a fuse on the left side and temps just kept creeping up in traffic. In high speed cruise, the F355 is very cool even when the fan didn't work.
    Note, fuse for fans are in the footwell, 30 or 25amps.
  4. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,707
    South East
    Jimmie
    #4 greyboxer, Jul 22, 2011
    Don't forget the book says only to start worrying above 239 F which I think is the mark where the red begins - if you live in a high ambient area your temperatures will be up currently especially if stationary - so it may be nothing but as noted check the fuses etc anyway
  5. F355Bob
    F355Bob Formula 3
    I had the same thing happen a few weeks ago. The right side fan did not come on. Fuses were good so I removed the fan. Turned out that the fan blades were loose on the motor shaft and just spinning freely. Changed out fan, now no overheating.
  6. FlyingAces
    Jun 2, 2011
    849
    LA 2 Vegas
    Joejoe
    Thanks guys will go over the items mentioned.
  7. FlyingAces
    Jun 2, 2011
    849
    LA 2 Vegas
    Joejoe
    I am so STOKED!!! it was the fuse..
    Thanks guys, that fan coming on is music to my ears
  8. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,666
    San Carlos, CA
    Mitchell Le
    You know that old fans are less efficient and draw more current which leads to blown fuses, right? It only gets worse from here. If the fuse keeps getting blown, you still need to change that fan.
  9. FerrariDeeJay
    Jun 2, 2009
    418
    Chino, CA
    Michael
    +1 Search the threads here on Fchat to buy aftermarket Spal fans. They are the same as oem with the exception that you have to reuse the old connector. You will save big bucks this way. Good luck.
  10. sws4re
    sws4re Formula Junior
    Jan 28, 2006
    281
    Olathe Ks
    Scott Sweat
    30102050 is the spal fan you want. It uses the factory plug and is a bolt in replacement. no need to switch out the plug.
