High voltage battery issue, need help | FerrariChat
Discussion in 'SF90 Stradale' started by greenbeast, Mar 6, 2023.
  1. greenbeast
    greenbeast Rookie
    Jan 20, 2015
    25
    Panamá
    Tony ng
    hello guys
    I haven't used my SF90 for about 3 months and now suddenly the agency tells me that the high voltage battery is discharged and is not charging.
    The car, while in the parking lot I always kept it charged with electric power.
    Can someone tell me if the same thing has happened to you and what would be the solution to get the battery to charge?
    Any thoughts?
    Thanks in advance
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,636
    South East
    Jimmie
    Take a look at the 'bricked' thread which may be similar to your experience
  3. greenbeast
    greenbeast Rookie
    Jan 20, 2015
    25
    Panamá
    Tony ng
    Thanks for replying
    Where is bricked thread located?
    Regards
  4. RumorDude
    RumorDude Formula Junior
    Dec 16, 2003
    625
    Woodinville, WA
    https://www.ferrarichat.com/forum/threads/bricked-sf90.644012/
    one thing that is also really important - you mentioned you had your car plugged in the whole time.
    the "order of plugging" is super important.
    when you park, (1) plug charger into wall. (2) plug charger into car.
    this order is very important!
    also, do not use an extension cord.
  5. 360spydr
    360spydr Formula Junior
    280
    Reno/Tahoe NV, Seattle WA and Portland OR
    KJ
  6. PA Wolfpacker
    PA Wolfpacker Formula Junior
    Aug 19, 2007
    682
    Naples, FL
    Neil
    Is this specifically for the SF90? My dealer told me a 12 gauge extension cord would work with my 812.
  7. RumorDude
    Dec 16, 2003
    625
    Woodinville, WA
    don't do it. the manual is very clear to not, and while i am 100% thinking "wtf it is just electricity", i did use also a 12g for about 15 min, and the cable was uncomfortably hot.
  8. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,174
    Denmark
    Max
    For an 812, you are just talking about a trickle charger. Nothing to do with a high voltage battery charger. The claim max current for it is 5A, under 12V. That's a 60Watt power. This translates to a .5A current on 110V, and .25A on 230V. Add in another 50% for losses (and that's definitely too much) and you are still at .75A max on 110V, .38A max on 230V. So any extension cord will do really.
