highest end WiFi routers and boosters? | Page 2 | FerrariChat
Discussion in 'Technology' started by rob lay, Nov 12, 2020.
  1. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,483
    Southlake, TX
    Rob Lay
  2. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    14,191
    MO
    Omar
    LoL!
    I just did my house as the Wifi was marginal and annoying me:
    Ubiquiti U6 long range x2 in the basement and a U7 Pro upstairs in the main room. I also upgrade the switch to a UniFi Switch Lite 8 given that it's POE+ and you need that for best results with the U6/U7 generation.
    Seems to have done the trick...send floor went from 20MBps to over 400 and no more random drop outs. I am sure there is higher end stuff out there but for a residential home the Ubiquiti stuff has been fine even when running/connecting double digit devices.
    vraa and rob lay like this.
  3. Whisky
    Whisky Three Time F1 World Champ
    32,575
    In the flight path to Offutt
    The original Fernando
    Back when I started dicking with WiFi here at home (year 2002~), I bought Linkys WRT-54's and then I
    downloaded aftermarket firmware from Sveasoft, which added a bunch of extra features, and
    one was I could adjust the transmit power up to a couple of watts, IIRC.
    THEN, Cisco bought out Linksys and almost immediately stripped-down all Linksys
    routers to the bare minimum of what they could do, less memory, less CPU speed, and you could no longer flash the firmware.
    Some places still make firmware you can use on certain routers today, but it is VERY specific as to
    which ones, which models, which versions, and in some cases, 'it can only be used on devices
    with a serial number starting with 123xxxxxxxxxxxx
    ' (123 is an example).
    I have not kept up in about 15 years, but if you want to look around, see if anyone still makes aftermarket
    firmware today, and what it will work on, and go shopping from there...
  4. vraa
    vraa F1 Rookie
    4,607
    Texas
    Mr. A
    Unifi products are just too cheap and too good to try to bother with fighting the hardware vendor
  5. Whisky
    32,575
    Some of us enjoyed playing.
    And I never 'fought with' anyone, just stated what I did, and what I learned.
    Boomhauer likes this.
  6. vraa
    vraa F1 Rookie
    4,607
    Texas
    Mr. A
    Yeah but the stakes were also a lot lower 15 years ago
    Today, you have a 0 day and all of a sudden you're running a tor exit for a pedofile and the feds are knocking on your door, not for the child porn, but because some north koreans used your router as a jump box to get DoD nuke codes
  7. Whisky
    32,575
    You're making a lot of assumptions there, I will just leave it at that.
  8. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,560
    FL
    That's pretty bad. My friend was trying to get me to use a mesh setup, but I didn't want to deal with that like he has (same neighborhood and house basically). I went with a TP Link 6e-capable and pretty happy with it. It was not the highest end unit, but good enough and no issues indoor or out (the Archer AXE75) and under $200. Their highest level seems to be $500 (Archer BE800).
  9. Innovativethinker
    Innovativethinker F1 World Champ
    10,123
    So Cal
    Mark Smith
    Uh, you might want to google tp link:
    https://nypost.com/2024/12/18/business/us-could-ban-chinese-made-tp-link-routers-over-hacking-fears-report/
  10. BMW.SauberF1Team
    Dec 4, 2004
    14,560
    FL
  11. Etcetera
    Etcetera Two Time F1 World Champ
    24,361
    C6H14O5
  12. sabre66
    sabre66 Rookie
    Jan 19, 2014
    19
    I used to use Ubiquity at home for my access points. I was using 3 of them upstairs, basement and out side. Reception was ok at best. Recently i replaced all 3 with 1 Ruckus R610 cheap on ebay $45 USD. Now I have great wifi inside and out. 500 Mbps no problem, even 4 houses away.
