Hill Eng end of stroke pin wrench rental? | FerrariChat
Discussion in '360/430' started by swc5150, Sep 14, 2023.
  1. swc5150
    swc5150 Formula Junior
    725
    Wisconsin
    Scott Calderwood
    Is there a source to rent the HE end of stoke pin wrench? Paying $200+ for a wrench I'll use once or maybe twice is a little tough to swallow.
  2. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,853
    Memphis, TN
    A lot of these special tools can be 3D printed in plastic. I just finished a belt job on my 360 and printed four special tools. Cost: $10.
    swc5150 likes this.
  3. swc5150
    725
    Wisconsin
    Scott Calderwood
    How do you go about doing this? The tool you features in the other thread looks perfect.
  4. EastMemphis
    May 25, 2019
    1,853
    Memphis, TN
    If you have a picture of the existing tool, that can help a lot for reverse engineering. You'll need to have access to a CAD program that can create 3D models which is pretty much any, and then design the tool.
    A digital caliper and inside and outside calipers are pretty much required for most jobs like this, and of course, access to a 3D printer.
    Post a picture of the tool and the part it attaches to, and a description of what it's supposed to do, and I'll see if I can offer any other advice.
  5. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    A few thoughts...
    1. A plastic tool will not be man enough to undo end of stroke studs that have been siliconed in.
    2. Even the Hill wrench has a somewhat limited life (which can be extended by dressing the business end of the wrench). Having one of these tools as a rental probably wouldn't work for long.
    If you want to remove the studs without the tool, cut the ends off the studs with a dremel and use a deep socket once the release bearing is out of the way. You'll need new studs but you'd probably need them anyway once you'd rounded them off with the wrench....
    Rifledriver and EastMemphis like this.
  6. 67bmer
    67bmer F1 Rookie
    2,966
    MD
    yes - cut them off with a Dremel and replace. That's how I ended up. I think there is also thread lock on them.
  7. swc5150
    725
    Wisconsin
    Scott Calderwood
    I did get new pins so cutting out the old ones is a good idea. But how do you then install the new ones?
  8. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    EastMemphis, swc5150 and AandSC like this.
  9. yelcab
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    I couldn't wait for the tool to arrive so I just welded one. I don't think a 3D printed one would work in this case.
    EastMemphis likes this.
  10. EastMemphis
    May 25, 2019
    1,853
    Memphis, TN
    Pretty much anything that's long, thin, and requires a lot of torque is way beyond what 3D printed plastic can do.
  11. swc5150
    725
    Wisconsin
    Scott Calderwood
    Has anyone tried a flex head wrench? Seems like that would work, although I haven't torn it apart yet. I'm guessing I'm not the first person to think of this, so prob not?
    It's a 13mm crow foot right?
  12. yelcab
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    Flex head won't work. There is very limited access to the 13mm headed bolt. You can't see it with my franken-tool but I ...
    1) Cut the end off the 13mm wrench
    2) Turned it 90 degrees and welded it back on the brake line wrench (that has 6 points of engagement)
    3) Ground off some of the end to make it thinner to clear access at the site
    4) Then welded on the little extension to give it 3/8 ratchet engagement so you can torque it.
    EastMemphis and swc5150 like this.
  13. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    very clever and makes good sense
