Hills Pedals Fitting Dilema | Page 2 | FerrariChat
Discussion in '348/355' started by 348Jeff, Jun 18, 2014.
  1. AceMaster
    Feb 6, 2009
    34,785
    Ontario, Canada
    Jeff, for your safety and the safety of others, please drill them in.
    You're out numbered, there isn't a single poster in this thread that supports the glue-job.
  2. fatbillybob
    Aug 10, 2002
    29,252
    socal
    90% of DIY'ers are hacks. 90% of pros are hacks too. Maybe it is just 90% of people are hacks.
    Taz made a very important point. Please don't add these pedals as a fashion statement. Set them up for proper heal and toe or just leave them stock.
  3. cuneo
    cuneo Formula 3
    2,484
    #28 cuneo, Jun 21, 2014
  4. cuneo
    cuneo Formula 3
    2,484
    Seriously tho, save the children in the crosswalk. Screw them on properly!!
  5. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    #30 348Jeff, Jun 21, 2014
  6. tazandjan
    39,312
    Jeff- That ought to do it. Improves the ambiance, too. The silver tape is a nice touch.
  7. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    On a more serious note - no-ones put forth any reasonable argument other than scaremongering and TBH since none of you have actually seen it I'm not sure what the basis of the criticism is.
    All I've done in effect is replaced some rubber pedal covers attached with a bit of contact adhesive with some metal "pedal covers" which are now much more firmly attached.
    Not aware of anyone whose bolted their existing rubber pedal covers on so I suppose they had better be careful out there too...
  8. tazandjan
    39,312
    Jeff- The rubber pedals fit around the metal pedals, not just on top of them.
  9. Rifledriver
    37,288
    If you really cannot see the difference then you should limit your auto servicing to putting air in the tires.
  10. Shark01
    Shark01 F1 Veteran
    Jun 25, 2005
    6,521
    After reading his latest posts, I'm thinking putting air in isn't the best idea either....
    Adhesives suck in dynamic environments.....I had lots of failures leading up to my patent. Statically, the adhesive was great, but once the machinery was switched on things could go to hell within weeks.
  11. AceMaster
    Feb 6, 2009
    34,785
    Ontario, Canada
    There is a time and a place for fun and games....this topic is not one of them.
  12. flyingboa
    flyingboa Formula 3
    Nov 27, 2003
    1,564
    Italy
    Eugenio Dalla Rosa
    Jeff,
    It is your car and your judgement is for sure a good one. I did follow every bit of the activities you did on your car, and they are great.
    It seems that you have taken your decision, and that you will not change it. But...
    Do you really think that just a little hole in the pedal will affect your car originality?
    Even if there is a 0.01 % chance only of having problems, why take it?
    Just drill them and go the safer way :)
    Ciao
    Eugenio
  13. plugzit
    plugzit F1 Veteran
    7,791
    Redondo Beach, CA
    Bruce Bogart
    I hope you used only the freshest, highest quality duct tape! :)
  14. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    I haven't actually ruled out drilling them. As mentioned earlier on I was actually surprised at how well they adhered - there's no movement or twisting and they are more secure than the original rubbers which can be twisted off very easily despite having a lip.
    The plan is to use them as they are and see how it goes - if they appear to be loosening in any way Ill add the bolts without delay. I am certain that they wont just drop off instantly and if people knew my character they'd know I do take safety very seriously so I dont view myself as "taking a chance".
    I will report back if the situation changes or I can find a way to demonstrate it easily - bit difficult to show something not moving.
  15. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    #40 driveitdaily, Jun 21, 2014
    Not to add fuel to the fire, ( i have these covers and bolted them ) but , and this is unrelated , the standard has changed in our bodyshop in respect to structural body panels , roofs , quarter panels , .... In the past these repairs required welding on new panels , now the procedure is to bond them with the proper bonding agents, with the emphasis on " proper "
    I know that sounds crazy , but when your wife cracks up the camry, the bodyshop is probably going to glue the new quarter panel on.
    Just some food for thought
    " serenity now "
  16. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Absolutely priceless. Mind if I use that? :D
