Hints on oil pan gasket replacement for a 328? | FerrariChat
Discussion in 'Technical Q&A' started by hustonm3, Feb 24, 2004.
  1. hustonm3
    hustonm3 Rookie
    Nov 13, 2003
    31
    Londonderry, N.H.
    Mark H.
    Replacement of my pan gasket needed, are there any additional parts that need to be removed other than the pan bolts? Also need the torque value for the pan bolts/nuts if anyone has it handy.
  2. Steve Magnusson
    26,826
    Which pan -- engine or gearbox?
  3. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    I would remove the oil dipstick tube as this can hold up the pan on 308s. 328s might be slightly different but I am thinking they are the same.
  4. hustonm3
    hustonm3 Rookie
    Nov 13, 2003
    31
    Londonderry, N.H.
    Mark H.
    I'm changing the engine oil pan gasket, found a few threads in the archives but not for the 328. Removing the dipstick tube seems to be a pressue fit tube assy., easy as pulling it out ? or more involved than that ?
    Still looking for the correct torque for the pan bolts, anyone ?
    Thanks in advance !!!
