Hitechexotic Kevlar clutch | FerrariChat
Discussion in '360/430' started by X-911 TURBO, Feb 3, 2014.
  1. X-911 TURBO
    X-911 TURBO Rookie
    Jun 21, 2013
    21
    Anybody know anything about this company (no address or phone number in their website) but I found them in EBAY saying three times the clutch life. Have a '07 Spider with F1 and would be interested if the claim is true.
    Also, what is the approx labor charge ($ and hours) to replace a clutch?
  2. tazandjan
    39,176
    Kevlar clutches have not matched up well with F1 Ferraris.
  3. ncjetskier
    ncjetskier Formula 3
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    To replace a clutch is 20 labor hours at $125 per hour. I was told that they would only charge me $100 per hour.
    I looked into using a Kevlar clutch - seems like they may last a lot longer, but also may have many problems such as a "break in period" and generating a lot of heat.
    I spoke to Clutch Masters (you can find their contact information on the internet). They were good to speak with and willing to answer whatever questions I had. They rebuild your clutch using Kevlar.
    The main problem that I found was that if I brought any parts to be used in the clutch replacement (Hill Engineering throw out bearing, Kevlar Clutch) then the dealership would not offer the 2 year warranty. Given the cost of $6,200 plus tax, I was not willing to take the chance.
  4. Camdon53
    Camdon53 Formula Junior
    Jul 18, 2006
    507
    Texas, USA
    Jim
    The Kevlar and carbon fiber clutch plates can be (and have been) made to work in a Ferrari F1 system. The fundamental problem is that the surface friction characteristics and various other physical moduli (e.g., coefficient of linear expansion) are quite different from the OEM material. Therefore, the factory software controlling clutch engagement in the TCU is quite inappropriate since it expects to be working with an OEM clutch plate.
    That means when one of these non-OEM clutches is simply substituted into the system with no other changes, all kinds of nasty problems result (e.g., overheating flywheel and/or pressure plate, jerky and erratic performance, premature wear of all components, etc.). The only solution is to completely re-program the TCU to precisely match the new & different characteristics of the clutch plate. If you can do that, there may be some advantage. Otherwise, not so much.
  5. djantlive
    djantlive Formula 3
    Jun 30, 2005
    1,015
    search on the lambo forums. covered extensively there
    underground racing requires its 1200+ hp to have kevlar clutch units.
    i suggest going with a stock clutch unless you get warranty from the installer.
  6. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    Try HR clutch ...many hAve had success with rebuilt units
  7. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Really?
    Maybe for a DIY'r doing it for the first time!
  8. DonJuan348
    Aug 5, 2008
    4,442
    Taxing Jersey
    How many hours for professional
  9. gman3280
    gman3280 Rookie
    Jan 10, 2014
    37
    Atlanta, GA
    I've searched for an 430 clutch DIY and didn't find much. Clutches are not that difficult. From what I've read, everyone is an expert, apparently the car needs to be hooked up to the computer to have values reset so the computer operates properly.
  10. tazandjan
    39,176
    For F1 clutches, an SD2/3, depending on model, is required for setting clutch point of initial slippage.
  11. DonJuan348
    Aug 5, 2008
    4,442
    Taxing Jersey
    On a manual tranny ...how many hours should it take? And any special calibrations needed...I've always wondered this
  12. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    8-10 hours is a decent time for a 360. I can't see a 430 being that much more than that unless one of the pros want's to correct me.
    Maybe they include the time to air-freight the clutch from Italy....
  13. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    I will post a breakdown of the bill when I receive it. Another mechanic (Classic Coach in Raliegh, NC) stated 15 hours. I guess the real question is: What have you paid to have a F1 clutch replaced?
