For Sale - Hk SP5 9mm 100% NIB | Page 2 | FerrariChat
For Sale Hk SP5 9mm 100% NIB
Discussion in 'Other Parts & Collectibles' started by ralfabco, May 26, 2022.
  1. ralfabco
    ralfabco Two Time F1 World Champ
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    If it makes this any easier, I am located in Houston :D
    Ghostdiver likes this.
  2. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,242
    Huntsville, AL., USA
    Andrew
    Is H&K's factory warranty transferable to the purchaser?
    All the best,
    Andrew.
  3. ralfabco
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    Hi Andrew,
    No. The first post mentions this is not a Hk USA product. This SP5 is marketed, by Hk GmbH.
  4. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,242
    Andrew
    It looks like all SP5 products are manufactured in the exact same factory in Oberndorf, Germany before distribution around the world:
    https://hk-usa.com/sp5/
    "Heckler & Koch is proud to announce the US availability of the HK SP5, the only authentic sporting version of the legendary MP5 submachine gun available.
    {...} The SP5 is manufactured in Heckler & Koch’s Oberndorf factory in southwest Germany."
    So why bother to import one yourself in the first place when it loses the factory warranty to do so?
    All the best,
    Andrew.
  5. ralfabco
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    #30 ralfabco, Jun 5, 2022
    This item is not for you, if you need a factory warranty. The SP5 is known to be a reliable firearm. The biggest issue with the SP5 is the extractor spring which should be replaced every 5-10K rounds. Some claim 30K rounds. The extractor spring is inexpensive and available. Several owners just buy the extractor springs and replace the part well before it requires changing it out.
    MP5 recoil spring lifespan | HKPRO Forums
    I did not import this firearm.
    Yes all of these are produced under the same roof. One benefit with the Hk GmbH SP5, is the absence of the WARNING: read owner's manual and other information - which is painted on the right side of the receiver. This item also comes with a full-size hard case which I find more tasteful.
  6. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,242
    Andrew
    Heckler & Koch GmbH is the manufacturer rather than the marketer. The importer of guns brought out of Germany, such as "HK Inc. Columbus, GA", will also be stamped on the receiver. Who is stamped as the importer on this particular firearm?
    All the best,
    Andrew.
  7. ralfabco
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    HK GmbH also markets the items in Europe and outside the euro zone.
    Hk will exhibit (market) their products at eurosatory and other regional shows. https://www.bing.com/search?q=eurosatory&cvid=ebb4d1542dae4ac4b0bf04f932fbeb8a&aqs=edge.0.0l9.7982j0j1&pglt=43&FORM=ANNTA1&PC=U531
    https://www.bing.com/search?q=milpol&form=ANNTH1&refig=4b881e847811453dbae49bde3524b6aa
    No clue at the moment who imported the pistols into the USA. I do not have the pistol in my lap.
    Do you need to know the corporate name of the importer.
  8. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,242
    Andrew
    My understanding is that the name of the importer must be stamped on the actual firearm:
    https://www.atf.gov/firearms/firearms-guides-importation-verification-firearms-ammunition-firearms-verification-overview#
    Name of Importer
    Must be conspicuously engraved, cast or stamped (impressed) on the firearm frame, receiver, barrel or slide
    For firearms imported after January 30, 2002, the engraving, casting or stamping (impressing) of the importer’s name must be to a minimum depth of .003 inch
    All the best,
    Andrew.
