News
Hole inside the rim?
Discussion in 'Technical Q&A' started by paulchua, Nov 17, 2018.
  1. INRange
    INRange Formula 3
    2,455
    Virginia
    JD
    How did #21 come off if the cable that runs through it is still attached?
    paulchua likes this.
  2. absostone
    absostone F1 Rookie
    3,941
    Fchat
    someone shot a 9mm at the wheel from the grassy knoll I guess
    paulchua and INRange like this.
  3. INRange
    INRange Formula 3
    2,455
    Virginia
    JD
    I'll bet $5 that the missing part had the same diameter as the rim hole....
    willrace and paulchua like this.
  4. theunissenguido
    theunissenguido Formula 3
    Silver Subscribed Owner
    Jan 21, 2004
    1,331
    Argent/Brasil/Blgium
    Guido
    I also think part 21 is the missing link. Hand brake Cable came loose for some reason, this whas the ratling noise you hear and after part 21 whas going over the cable at his end, got trapped between wheel and brake caliper and the turning wheel forced part 21 over cable end, making this hole and went lost in nature...
    Guido
    paulchua and WaltP like this.
  5. Wade
    Wade Two Time F1 World Champ
    Rossa Subscribed Owner
    Mar 31, 2006
    25,177
    East Central, FL
    Wade O.
  6. absostone
    absostone F1 Rookie
    3,941
    Fchat
  7. Wade
    Mar 31, 2006
    25,177
    East Central, FL
    Wade O.
    That's Space Walkers, not street walkers. :D
  8. absostone
    absostone F1 Rookie
    3,941
    Fchat
    haa lol
  9. paulchua
    paulchua Cat Herder
    Moderator Rossa Subscribed Owner
    Jul 1, 2013
    5,948
    Menlo Park, CA
    Paul Chua
    I have no clue! I have part #21 on route and I will measure to see if it's possible to have it jam between the roter and the rim, I still think it was something else - but it does make sense if it was the right fit.
  10. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    5,948
    Menlo Park, CA
    Paul Chua
    Thanks solid state, I will make sure to measure and report back to here. I appreciate you taking time to respond.
    Solid State likes this.
  11. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    5,948
    Menlo Park, CA
    Paul Chua
    thanks so much absostone, when the part comes I will measure and report back, I'm super confused and appreciate all the responses.
  12. absostone
    absostone F1 Rookie
    3,941
    Fchat
    no prob pal thank u
  13. INRange
    INRange Formula 3
    2,455
    Virginia
    JD
    They need this guy on the space station.
    f355spider and paulchua like this.
  14. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    5,948
    Menlo Park, CA
    Paul Chua
    I never updated the community.
    I think I traced it to the emergency brake cover, I believe it got dislodged and got caught between the rotor and rim. Probably punched a hole - still just a guess, but it's the best I came up with.
    Cheers
  15. f355spider
    f355spider F1 World Champ
    May 29, 2001
    16,562
    Hugh G. Rection
    Seems like a reasonable explanation, that the smaller end of that part, with enough velocity, punched the hole and made the "slug". Good detective work.
