holy oil scraper ring Batman | FerrariChat
Discussion in '308/328' started by Ferraripilot, Feb 13, 2010.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,849
    Atlanta
    John!
    #1 Ferraripilot, Feb 13, 2010
    Thanks to Dave on the underside of the planet, the hi-comp pistons made it! The material published for the lemans spec Borgo pistons is that the top and second rings are 1.5mm with a 2.8mm oil scraper. The first two specs are true, but the oil scrapers measure out to be a gigantic 5mm! I am going to call NPR or Total seal and see what we can do to get these things. I don't know of anything other than a Lamborghini 350 V12 and early Porsche 356 which uses an oil scraper this size. The two top rings are the easy part as a mid-'80s Toyota Corolla uses identical rings. Hopefully putting this ring pack together won't be a bigger deal than it needs to be.
    As for the great big dome, it is somewhere between 15cc and 16cc and protrudes .340" from the deck of the piston. This is freaking huge compared to the stock 5.8cc dome.
    If anyone has suggestions other than what I am planning for scraper rings, let me know!
  2. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    Maybe cut for a std US 3/16" oil control ring set?
    .187" = 4.75MM. Dunno how tight they are supposed to fit when installed, I never measured clearance after installation.
    Doug
  3. Ferraripilot
    May 10, 2006
    17,849
    Atlanta
    John!
    nope, won't work. there are specific 5mm scraper rings out there, just not many use them. I suspect this is because an oil control ring does not need to be even close to that size
  4. GrayTA
    GrayTA F1 World Champ
    15,130
    Deep South
    PDG
    #4 GrayTA, Feb 13, 2010
    Are you rebuilding your engine or something??
    Or more specifically, what is your project?? FWIW I would be glad to come up and help out - I know you know TONS more about this stuff than I do. So I have a free pair of hands anytime I can make it up there!!
    PDG
  5. Ferraripilot
    May 10, 2006
    17,849
    Atlanta
    John!
    Hey man, once I get the time to actually do this you're on. With another baby coming in May it may be a while
  6. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    John, you too?
    What's going on around here?? :)
  7. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,448
    Canada
    Newman
    Its callled sex, been a while? :)
  8. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,663
    Engine Bay, Georgia
    George C.
    Personally, I think it's something in the water. Could be something the government has cooked up relating to the upcoming census. Congrats - John!
    Ciao,
    George
  9. Ferraripilot
    May 10, 2006
    17,849
    Atlanta
    John!
    LMAO. Chris my man, the barn door was left open on that one.
  10. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    I should have known Paul was waiting on the sidelines. :)
