HOLY ****! Spark plug wires! | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by cmparrenzo, Sep 7, 2005.
  1. cmparrenzo
    cmparrenzo F1 Rookie
    Mar 3, 2002
    2,687
    Kansas
    Chris Parr
    The F40 was starting to develop a high speed miss, felt like a bad spark plug.
    Chris Hill at Autosport replaced all the plugs, it helped, but did not cure the problem. Upon investigation we discovered 4 wires that were severly corroded. Chris said he would order just those wires, I told him it was crazy only to replace 4 of the 8 wires...
    Then he told me the wires ranged from $135 to $475.00 per wire! A new set is about $3,600.00!
    So.......... I guess I am replacing 4 wires since the other 4 are in perfect shape...
    This is my first such issue with the F40, so I guess I am lucky, I understand GTO's and 512TR's have the same issue...
    These spark plug wires sure give you a shock!
  2. titanium360
    titanium360 F1 Rookie
    3,446
    chris try A-W imports in New Jersey and ask for Frank. he might be able to save you some money
  3. zsnnf
    zsnnf Formula 3
    Sep 11, 2003
    1,877
    Yep!!! We replaced 2 on my rebuild and then one got burned on the Dyno!! Of course it was one of the new ones! Ouch!!
  4. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    Please inform me why these cannot be made even for half that cost? What is special? The socket itself? Shielding? Or the prancing horse on the shielding?
  5. cmparrenzo
    Mar 3, 2002
    2,687
    Kansas
    Chris Parr
    nothing too special excpt that the metals ends are unique. mine are too far gone to be reused...
  6. f355spider
    f355spider F1 World Champ
    18,048
    Actually, there are outfits that will make replacements if you send them a sample of what you want.
    Check this place out: http://www.kingsborne.com/ They carry all the components too, like the Beru connectors used by Ferrari and Porsche.
    Look under "other products", then under "connectors".
    Dave
  7. TomDial
    TomDial Rookie
    Aug 6, 2004
    36
    Europe
    Chris
    There is nothing special about the wires in a Ferrari. They are as standard as the water you fill in the windshield wiper tank.
    High quality high temperature silicone is perfect for any turbo charged car. As the F40 plugs (NGK C8E) are non resistor type, the resistor has to be in the wire or connectors. But anyone who reconditions such wires will know. $3600 is a little too much... I’m sure you will get them 90% cheaper if you try. And don’t expect original Ferrari parts to be to be best quality you can buy!
  8. DeuceRooster
    DeuceRooster Karting
    Jun 11, 2005
    163
    Kentucky
    Dustin
    Wow and I thought $1200 was high for a set of BMW 750 wires!
  9. mrknowitallf40
    mrknowitallf40 Formula Junior
    Feb 20, 2005
    306
    Buy some cheap wires at Summit racing and cut them up. Or you can call Truechoice and they can get you some Magnecor wires custom made. They look just like stock. The wire can be replaces separate of the plug end boot which is probably the expensicve piece. While you are at it have your coils checked (They frequently fail and cause fires). Your car seemed to be running a little rough in Monterey. I wonder if your fusebox is OK. I am pulling mine this weekend for an inspection.
  10. cmparrenzo
    Mar 3, 2002
    2,687
    Kansas
    Chris Parr
    Well 4 of the plug wires were corroded, that is the easy part, the wires cleaned up the plug extensions were also corroded and they are beyond repair.
    I noticed the rough running for the first time in Monterey, but it really became apperant on my high speed run to Big Sur...
    We first put in new plugs today and that helped, but that is when we isolated the problem to the plug wires and extensions. The wires are actually fine, but the extensions have to be replaced. The source listed above (Kingsborne)does have replacement wires for far less than Ferrari, but alas, no replacement extensions for a F40.
    We will see if this is a 100% cure on Friday when the new wires and extensions are installed...
    cross your fingers!
  11. Hans Gruber
    Hans Gruber Karting
    Nov 16, 2004
    84
    That kind of money for plug wires is simply highway robbery. I would refuse to pay that just for the point.
    I had a few wires melt on my car so I just went down to my local performance parts shop, bough an 8 foot spool of MSD brand Super Conductor wires (very nice quality and probably identical if not better than OEM Ferrari wires or any other OEM), a few clips (you could probably re-use these as well if they are not corroded), crimping tool and just made my own wires for less than the price of the junk OEM wires. The valve cover boots you will have to re-use, just cut the old wires and they should slide off.
    8' spool..............$80 if I recall correctly
    cimping tool........$10
    plug/coil clips......$10
  12. cmparrenzo
    Mar 3, 2002
    2,687
    Kansas
    Chris Parr
    Hans, thanks for your comments, but it is not the wire it is the extensions that need to be replaced. Ferrari will not just sell the extensions, the wire and the extension is the only way you can buy it...
  13. Hans Gruber
    Hans Gruber Karting
    Nov 16, 2004
    84
    Oh I see, I just skimmed by the later posts....
    I bet the same extensions were used on more than just the F40 they just make another part # for the F40 even though it's the same part used on another model, so there may be a cheaper aftermarket alternative.
    Perhaps:
    http://www.italiancarparts.com/ignitionwires/ignitionwires.html
  14. Ricambi America
    Sponsor Owner
    #14 Ricambi America, Sep 8, 2005
  15. mark328
    mark328 Guest
    Jul 30, 2005
    664
    Mi
    Mark
    Buy them online and put them on yourself. Just replace them one at a time so you don't get them crossed or forget what order they go in.
  16. mrknowitallf40
    Feb 20, 2005
    306
    The F40 head is the same design as the 328 QV. Does it use angled plug ends or are these straight? I am still interested in doing the coil-on-plug conversion but so far I have not found a suitable COP that fits correctly or that is CDI compatible. Any ideas? I remember a post where someone did a 328 QV.
  17. mrknowitallf40
    Feb 20, 2005
    306
    Hans, I have the straight pipes as well. Too much attention from the Cops and earplugs required. The smell of an F40 with on cats and on race gas will tahe you back to the traffic jams of the 70's.
