Home Smog PreTest? | FerrariChat
Home Smog PreTest?
Discussion in 'Technical Q&A' started by donaldh2o, Mar 30, 2004.
  1. donaldh2o
    donaldh2o Karting
    Nov 10, 2003
    143
    Irvine CA
    Don
    Is there any way to tell whether the carbed 308 is running rich or lean without an elaborate CO tester?
    Mine failed the California smog test months ago. It was running too rich. Too much CO. Now I've finally finished tuning it up and need to pre-test it before I take it for an actual smog test.
    I've already turned all eigtht carburetor mixture screws all the way in and then backed them off 3 turns (and I assume the manual means 360 degree turns).
    The carburetors are all balanced at about 3.75 kg/h using the SK-1 synchrometer and the idle is set at abouit 900 rpm. Timing is set about 8' or 9' before tdc.
    Is there a clever home method of pretesting the CO level?
    Like maybe holding a peeled apple or potato up to the exhaust and if it turns a certain color its rich and another color if its lean?
  2. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Well Don I'm impressed if you can get you car to run on 3 turns out on the carbs. The air bal. seems right but with 3 turns you should be running to lean. I need to crank my out to around 6-7 turns to get to run great up at top end. It is rich at idle but goes like hell when you light it up. I would suggest you get a colortune kit and do each cyl. at a time Then tweek it back a hair to lean it up for the smog test. I also run my timing at 7 deg.
  3. PeterS
    PeterS Five Time F1 World Champ
    52,603
    Goodyear, AZ
    PeterS
    "Like maybe holding a peeled apple or potato up to the exhaust and if it turns a certain color its rich and another color if its lean?".........
    ..I tried this with my EX and it did not work to well. When she turned blue, the engine was still running rich.
  4. donaldh2o
    donaldh2o Karting
    Nov 10, 2003
    143
    Irvine CA
    Don
    So Steve, you've used this Colortune kit on a 308?
    I saw this thing while net surfing for a new SK-1 synchrometer. It looked interesting and it seems to be popular with Volkswagen bug tuners. My first thoughts is that it would be too recessed in the 308 valve cover to be seen clearly.
    But if it works on a 308, that would make it a valuable tuning tool.
  5. zan
    zan Formula Junior
    Nov 15, 2002
    537
    Boston
    Mark M
    Lock your wife in the garage with the engine running, if she's still breathing in half an hour, you CO levels are OK.
  6. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,471
    SFPD
    Dirty Harry
    Is the car OK, though?
  7. Steve Magnusson
    26,931
    Don -- What's the CO at-tailpipe test target that you're trying to meet?
  8. nautique
    nautique Rookie
    Nov 1, 2003
    20
    Los angelas, CA
    Craig Tempelton
    Don,
    Unfortunately in California, you will probably get put on the dyno test machine. This does not test your car at idle, it test while running. A colortune is great for setting your idle mixture but will not help you pass the ca smog test.
    I go through this every 2 years. You need to find a shop that will pre-test your car without sending the data to the DMV. If your car is running good it probably will not pass. You will have to test and then re-jet the carbs. I had to jet at 50 idle circuit and 120 mains (car ran bad but passed). I probably could have run 52 and 122 but did not have any.
    Good luck, it always takes me about 4 or 5 pre-test to pass
  9. Wayne 962
    Wayne 962 Formula Junior
    503
