Home theater audio question | FerrariChat
Discussion in 'Technology' started by Daryl, Apr 23, 2016.
  1. Daryl
    Daryl Formula 3
    Nov 10, 2003
    1,035
    Barrington Hills, IL
    Daryl Adams
    Maybe some of you audio geeks can help me out here. I have a surround sound audio system (Sony) paired with my HD TV and cable system. Recently I've started having trouble with the voice (center) channel. For example, I'll be watching an F1 race and the dialog between Matchet, Hobbs and Diffey will start to fade away. Over a period of 30 seconds or so it will disappear entirely. The rest of the audio (cars, background track sounds, etc) stays unchanged. The only way to get the voice channel back is to start increasing the volume. At some point (after the volume is uncomfortably high) the voice channel pops back in and I can then back the volume down to the correct level. The tuner is not that old, as I got it at the same time I purchased my HDTV. I'm about ready to trash the whole thing and replace it. Any ideas?
  2. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    The most common problem with AV receivers seems to be faults in the HDMI switching board. You might try swapping to another HDMI input on the receiver to see if that helps.
  3. classic308
    classic308 F1 Veteran
    Jan 9, 2004
    6,820
    Westchester, NY
    Paul
    And that's bad?
    Seriously I agree the hdmi board may be having issues.
  4. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    Speak with Rod @ Simply Stereo in Hoffman Est. on Higgins.
    Don't let the look of the store put you off, Rod is a home theater expert and great to do business with.
  5. TheBigEasy
    TheBigEasy F1 World Champ
    Jun 21, 2005
    18,642
    California
    Ethan Hunt
    With all the technological advancement in home entertainment... .I'm kinda amazed that A/V receivers haven't progressed much at at all.
  6. stretchgeneral
    stretchgeneral Formula 3
    1,438
    MA/TX
    McK
    Run another source material (blue ray or CD) through the HDMI input that had the fade issue. If the problem is in the receiver in that HDMI input, it should repeat the problem with another source. If it doesn't then it is not the receiver, but a signal processing lapse with the cable/satellite provider, IMHO.
  7. vincent355
    vincent355 F1 Veteran
    6,513
    Wine Country
    Vincent
    Happened to me on a Bose system. It was the hdmi cable in my case.
  8. darth550
    Jul 14, 2003
    61,114
    In front of you
    BCHC
    I just had my first Bose glitch after 4 years. Turned it off and on an few times and it popped back on.
