HondaJet begins FAA certification process | Page 4 | FerrariChat
Discussion in 'Aviation Chat' started by DMC, Dec 22, 2010.
  1. CavalloRosso
    CavalloRosso Formula 3
    Jul 12, 2007
    1,423
    Atlanta, GA/Vail, CO
    SVO
    It looks like a dolphin...I kinda like it!
  2. KKSBA
    KKSBA F1 World Champ
    15,303
    SBarbara-La Jolla CA
    KKSBA
    #77 KKSBA, Mar 19, 2015
  3. tazandjan
    39,408
    A pylon is a pylon. Regardless of where it is, hanging from the bottom of the wing or cantilevered sideways out of the fuselage, you just have to make it tough enough to take the loads.
  4. KKSBA
    15,303
    KKSBA
    Something about that placement just makes me think it will be in the right position to naturally suck in birds. Time will tell if there are an abnormal number of bird strikes and how the engine holds up.
    As for the engine and pylon, they are designed to shear under great load. You don't
    want it to rip the wing off.
  5. rdefabri
    rdefabri Three Time F1 World Champ
    Jun 4, 2008
    33,571
    NJ
    Rich
    Agreed - looks scary to me.
  6. jcurry
    24,153
    In the past
    Jim
    Don't birds generally have a tendency to dive? Which would make the above wing placement less likely to experience strikes.
    Most likely scenario for such loads is impact with the ground. Again above wing placement not likely to see such an impact.
  7. KKSBA
    15,303
    KKSBA
    I've seen birds go up, down, right, left! It depends also on what the aircraft is doing relative to the bird(s). I don't thing I've heard of bird suicide by fan jet :D so they would definitely try to avoid it... That is if they know what it is and see it in time.
    That gap between the nacelle and fuselage keeps drawing my eye and making me wonder about it being a bird vacuum. :D
  8. jcurry
    24,153
    In the past
    Jim
    Chance of FOD is pretty much zero, as well as water ingestion due to wheel spray. Put some low pressure tires on it and will make a nice unimproved strip airplane.
  9. Jason Crandall
    Jason Crandall F1 Veteran
    Mar 25, 2004
    6,375
    ATL/CHS/MIA
    Jason
    Birds do whatever they do. Never seen birds only dive. Some never move.
    HondaJet for unimproved strips??? I don't think they've made that claim in the sales literature. Are the engines any higher off the ground with OTWEM than they are mounted to the fuselage?
  10. jcurry
    24,153
    In the past
    Jim
    Its not only a question of how high off the ground, but if they are in a position to ingest debris kicked up by tires. The HondaJet engine position looks pretty immune to that.
    As far as birds, maybe its only ducks. Just something I recall reading. Best to just avoid regardless.
  11. TheMayor
    107,660
    Vegas baby
  12. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    My only thought was that it looked cool when it was announced even though you wondered at what their background and expertize were in small aviation. Heck, Mitsubishi built war planes but Honda? All the time the jet was represented as a low cost/affordable alternative from an entry level manufacturer. They were going to revolutionize the industry. $4.5 million is not revolutionary. Sorry, Honda. The jet also looks too small for practical use as a taxi.
  13. RacerX_GTO
    RacerX_GTO F1 World Champ
    14,978
    Oregon
    Gabe V.
  14. Jason Crandall
    Mar 25, 2004
    6,375
    ATL/CHS/MIA
    Jason
    The engines aren't attached to the fuselage but they are attached to the wing which is attached to the fuselage.......
    All airplanes are much quieter nowadays than they were just a few years ago. In my experience, it's not the engine making the most noise.... It's the air rushing over the airframe. The faster you go the louder it gets. The higher you go the more it quiets down (thinner air).
    Maybe the HondaJet is that much quieter. I'll have to ride in one to see.
  15. Gatorrari
    Gatorrari F1 World Champ
    16,554
    Georgia
    Jim Pernikoff
  16. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    It's nice to see you're not dead.
  17. Jeff Kennedy
    Jeff Kennedy F1 Veteran
    Oct 16, 2007
    6,889
    Edwardsville, IL
    Jeff Kennedy
    Beyond the noise I am curious about the vibration transfer to the cabin.
  18. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,018
    Shoreline,Washington
    Robert Parks
    I'm meeting with some of my buddies from work tomorrow and I'm going to ask what the structures and aero guys think about this thing.
  19. Jason Crandall
    Mar 25, 2004
    6,375
    ATL/CHS/MIA
    Jason
  20. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    It is interesting to note that modern GT race cars (serious ones) attach their wings to the car from the top of the wing to leave the lower wing surface clear.
    I assume this is because the lower surface of a wing is more important than the upper surface for generating down force. Would this be the same or the opposite for generating lift?
    Pete
  21. walnut
    walnut F1 Rookie
    3,096
    Maryland, USA
    Rich
    Would be the opposite. The GT wings with the top mounts are trying to not interrupt the low pressure air going under the wing (at least that's my understanding). Force is pushing down. On an airplane, that low pressure flow is above the wing, right where Honda has placed their engine mounts... who knows, certainly not I.
  22. sigar
    sigar F1 Rookie
    3,685
    NorCal
    Your observation seems correct to me. The engine mounted on top of the wing will definitely impede airflow and therefore lift, how significantly I don't know. However, the engines may be able to counteract that with induced lift although I doubt it.
  23. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Huntington Beach, CA
    Lou Boyer
    I saw the HondaJet takeoff in Narita yesterday. White/red paint scheme
