Honeycomb/hex front bumper grill | FerrariChat
Discussion in '360/430' started by Dr.Gee, Aug 10, 2018.
  1. Bwtyler85
    Bwtyler85 Karting
    Oct 25, 2015
    149
    Perth, Australia
    Ben Tyler
    Wouldn't have any effect on airflow to the radiators. Holes are quite large.
    Sent from my SM-N950F using Tapatalk
  2. 02360spider
    02360spider Formula 3
    1,730
    Dartmouth
    Richard oliveira
    Why not just buy cs front grills they look 10 times better then stock.
    Sent from my SM-G950U using Tapatalk
  3. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    #4 Dr.Gee, Aug 10, 2018
    I like the challenge grills but think these would look better matching the side hood vents. Also the C.S. mod costs about $1000 with the spacers.
    Plus,this looks thin enough to go over the existing stock grills without having to remove the bumper for install.conversely,easy removal and $50 cost should it not work out.
  4. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    23,084
    Honolulu
    Kevin
    No issue with airflow at all or cooling. I use an old school bra on mine and it has a mesh screen over the openings. I am curious what this will look like. Some of the ad pictures look like different products to me too.
  5. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    So,I ordered this stuff. I am going to try to overlay it on the stock grill. I can cut it very precisely with a dremmel, but my question is regarding obtaining the exact dimensions for the cut. Ideally, placing a cs replacement grill on the sheet and tracing would be best. Any thought on achieving exact dimensions without doing this? I’m currently at a loss.
  6. BAD430BENZ
    BAD430BENZ Formula Junior
    May 13, 2014
    709
    EL PASO , TX
    JASON
    a little cheaper and you get it faster than a month.........
    eBay item number:
    312179254532
  7. BAD430BENZ
    May 13, 2014
    709
    EL PASO , TX
    JASON
    I would remove the bumper and replace . I think this overlayed on the OEM will look funny .
  8. Streetsurfer
    Streetsurfer Formula Junior
    Dec 16, 2015
    934
    near Chicago
    Ron
    You can go to custom car grills dot com and check different flow rates for the various grill materials.
    I run a smaller mesh on my Abarth without issue.
  9. Streetsurfer
    Dec 16, 2015
    934
    near Chicago
    Ron
    Here is one over the stock honeycomb. I later swapped the temporary white ties with stainless that don't show up unless you look real close. When I pull the stock grill to do aux lighting and an air horn I may fasten it properly from behind. You will want to do a nicer job on your Ferrari, I’m sure. I made paper patterns and cut the mesh from that. This was a quick mock up before a road trip in order to keep excess bugs out of radiator. I later touched up the edge trim, smoothed out a few corners, and glued it on with weatherstripping adhesive in a few key spots, and at the joints. Edge trim obtained from the site I mentioned.
