Hooked on Paddles.....!!! | Page 2 | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by Kds, Sep 2, 2005.
  1. Westworld
    Westworld Three Time F1 World Champ
    32,423
    So whats the differnet between moving that and an automatic (the Porsche)?
    How does the SMG work?
    Basically, all the new models have some form of a semi-automatic system?
  2. maquino
    maquino Karting
    Jun 22, 2005
    219
    That's true, but I have driven a Maserati CambioCorsa on both street and highway, and found its paddle-access very ungainly when any drastic steering-wheel turning is involved.
    In a twisty highway situation I don't think you'd be making such sharp turns as to need to reposition your hands on the wheel, but you would still need to get to both paddles, requiring hand-repositioning. Or so I found on California #1. With buttons on the 9/3 wheelspokes, no problem.
    It's also true that I spend more off-wheel time with the 5-speed in my 328GTS, but it's also more fun. :)
  3. ylshih
    ylshih Shogun Assassin
    Honorary Owner
    Mar 21, 2004
    20,612
    Northern CA
    Yin
    I thought so too at one point, but I no longer think so. First finding a paddle isn't anywhere as distracting as taking your hand off the wheel to do a manual shift. The paddles are always in a known position, just as your manual shifter is, and the paddles are closer to hand. Second, you really shouldn't be shifting with extreme steering angles. On my car, I can reach the paddles with top or bottom fingers within about 90-120 degrees and that is a lot of steering input.
  4. Kds
    Kds F1 World Champ
    Interesting comments about stationary versus rotating paddles......I don't have an opinion on this yet except that I didn't find the BMW rotating paddles to be an annoyance.
  5. xs10shl
    xs10shl Formula 3
    Dec 17, 2003
    2,037
    San Francisco
    That's probably a matter of taste. I've found the placement of Porsche's up-down levers mounted on both sides of the wheel to be much more useful than Ferrari's stationary left-side right-side paddles.
  6. Dino Martini
    Dino Martini F1 Rookie
    Dec 21, 2004
    4,619
    Calgary Alberta
    Martin
    Automatic just sits in the "drive postition" Tiptronic can be in "drive postition", or the gear lever can be slid over to the right, into a seperate gear shift area. where if you push the lever up, the gear shifts up. If you push the lever down the shift goes down. No clutch to press.
    Automatic tranny just sits in drive, you dont push on the lever. A computer thingy changes the gear for you.
  7. Westworld
    32,423
    Where is the gear lever on the Tiptronic?
  8. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    My experience was very different, I have owned 03 Maser, 01 360, and 04 575 with paddles, and a 04 360 gearshift (in my opinion only way to own a 360, not enough torque for paddles) I bought an 05 M3 (though now gone), test drove both SMG and 6 speed, really do not like the SMg, nor the fact the that the paddles move. I love driving very twisty roads and it was not comfortable with the paddles moving.
  9. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    And, an F1 shifter will also get you "hooked" on buying new clutches.
  10. Brian C. Stradale
    Brian C. Stradale F1 Rookie
    Mar 17, 2002
    3,615
    Dallas, TX, USA
    Only with misuse... but misuse a standard shifter, and you could burn up the clutch even faster than any F1...
    Only difference is that its easier to not notice you're abusing an F1... your left leg has to work harder to abuse a standard shifter... but it can certainly be done.
  11. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Maybe, but I sure see a lot more F1 cars at the dealer for clutch replacement than I do stick shift cars.
  12. Doug.
    Doug. F1 Rookie
    3,308
    Las Vegas, NV
    still, i drove both versions and wasn't impressed. afterwards i got in a traditional manual car (m3) and it gave me 10x the excitement.
  13. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    I guess i'll have to actually try it. Just seems more like playing a video game than driving. Maybe I'm just old school.
  14. Brian C. Stradale
    Mar 17, 2002
    3,615
    Dallas, TX, USA
    That I do NOT doubt... its so easy to abuse an F1 clutch without noticing... for example, trying to creep slowly up a hill. In a stick, your left leg would be in pain and you'd know full well that you're slipping your clutch horribly for long periods of time. Its tiring and annoying... you'll stop doing it.
    In an F1, an unaware driver could do that for 10 minutes in traffic and seriously trash his clutch. But I consider that the driver's fault... and he could have done the same in the stick, but it would require a lot more left leg effort.
  15. Bart
    Bart Formula 3
    Nov 1, 2003
    1,522
    Orange County, Calif
    Bart
    Cut your left leg off. It is unless in driving.
    12 cylinders or walk.
