Horn location ? | FerrariChat
Horn location ?
Discussion in '308/328' started by Skippr1999, Sep 30, 2015.
  1. Skippr1999
    Skippr1999 F1 Rookie
    4,569
    I can't seem to find the location of the horn. How do you access the actual horn ?
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,833
    Cerritos, CA.
    If you are looking for the air compressor, it's located inside the left side front fender which is buried and hard to get to unless you remove the fender well ligning.
  3. Skippr1999
    4,569
  4. Skippr1999
    4,569
    Drivers side or passenger side ?
  5. miketuason
    Feb 24, 2006
    15,833
    Cerritos, CA.
    Driver side.
  6. ragtop1
    ragtop1 F1 Veteran
    5,258
    Ontario
    Larry Warren
    hmm...my compressor is on the passenger side. '79 gts
  7. Skippr1999
    4,569
    Anyone know for sure ? To get to it, remove wheel and wheel liner ? Horn not working and need to investigate.
  8. ragtop1
    ragtop1 F1 Veteran
    5,258
    Ontario
    Larry Warren
    #8 ragtop1, Sep 30, 2015
    mine is at the arrow. It will say Fiamm. There is an oil fill location. Yours may just need to be topped up. Mine quit working 2 years ago. I blew air through all the hoses, took the actual horns apart and cleaned everything. It was quite an easy procedure. When finished, the horns now sound much sharper and louder than before.
  9. miketuason
    Feb 24, 2006
    15,833
    Cerritos, CA.
    Yes, all 308 are on the right side then switched over to the left side on the 328s
  10. ragtop1
    ragtop1 F1 Veteran
    5,258
    Ontario
    Larry Warren
    ok thanks Mike, I didn't read Skipp's profile. 328 it is
  11. Mktwise
    Mktwise Karting
    Jul 25, 2013
    62
    San Jose, CA
    Michael
    Just needs some lubrication.
  12. Skippr1999
    4,569
    Thanks very much guys. So, drivers side for my 328. What kind of oil do you put in it ;). No another oil discussion !! Seriously ?
