hose replacement questions - Thoughts? | FerrariChat
Discussion in '308/328' started by qedqeq, Aug 3, 2015.
  1. qedqeq
    qedqeq Formula Junior
    Apr 15, 2015
    384
    Hi all,
    I am setting up my list of items to update on my 328GTB during the winter.
    One of the items that I am going to entertain is replacing all the hoses in the engine bay and brake lines too.
    One of the considerations will be going all factory stuff, but I am also thinking that I might go with more modern setup, maybe even color coded or steel braided,
    Kinda on the fence about dressing up the bay with non permanent addons.
    Your thoughts
    My car is a nero/nero 87 GTB, don't know what color, if I go with color at all.
    Regards
  2. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    For really, really good fuel and coolant hoses, correct in size, length and clamp (but admittedly looking more modern than oem) then go here:
    Scuderia Rampante
    Stocked by at least one of the site sponsors I think. With the value of the cars and the cost of leaking fuel or loss of coolant they make sense.
    Their petcock coolant drain is worth adding too - coolant draining becomes civilized...
    Guy
  3. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,532
    Raleigh
    Kevin
    In driver territory I just went with what was new and worked, which meant the cost was minimal. So that meant NAPA or Superformance. Works great :):).
  4. qedqeq
    Apr 15, 2015
    384
    Great Idea.
    Definitely want to spice up the engine bay, but I want totally tasteful, that will accent the red intake plenum and easily reversible when the time comes.
    Also something modern that won't look tired like these current hoses look after a couple of years.
  5. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    For what our cars are fetching, I can think of no better approach than installing the best parts you can find: lubricants, tires, hoses, bearings, brake maintenance, ect. ect.
    As my engineer once ruminated:
    "If you want first quality oats, you have to pay the price.
    If, on the other hand, you are willing to settle for oats that have passed through the horse...The price MAY be less".
    My sense is that our cars are approaching "collectible" status and thus not really valued for what we have aspired to make them, but rather, "How close to dead stock they are".
    This chaffes a bit, but it is the way things are.
    Keep all of your old take off's and parts, some fool may want to reinstall them.
    chris
  6. qedqeq
    Apr 15, 2015
    384
    That is the intent of this winter project, everything bolt-on and reversible, just in case someday, someone wants to return it to original.
    Regards,
  7. Kidasters
    Kidasters Formula Junior
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    When replacing fuel lines, I ordered some from Jegs that were ethanol resistant. That's what I would recommend.
  8. electrogunner
    electrogunner Formula Junior
    Sep 2, 2013
    322
    Amish country PA
    Joe
    Yes, I'm one of the crazies that keeps a trash bag full of all of the original take off hoses. ;)
    Sent from my SM-P905V using Tapatalk
  9. jdamon
    jdamon Formula Junior
    Jul 6, 2015
    288
    Boston
    Jeff
    I would like to replace all my hoses as well, but am a bit concerned about changing the stock appearance. What about using the oem parts from ricambi? They might be junk against etoh, but they have lasted 32 years so far in my case. New oems have to last for a little while at least, maybe 5-10 years? Correct me if I am off in my estimation, thanks!
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,677
    San Carlos, CA
    Mitchell Le
    Anything that has lasted 32 years cannot be considered ... junk.
  11. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    Be careful with steel braided hoses. They can rub a hole in anything they touch! Especially gas tanks.
  12. Rifledriver
    37,288
    Tasteful means black rubber and no aeroquip.
    That is unless lowrider bling is tasteful in your particular situation.
  13. Dr Tommy Cosgrove
    36,611
    Birmingham, AL
    Tommy
    Those factory hoses 32 years ago didn't have to put up with the gas we have now for the first, what , 15 years or so? I doubt that same hose material could make it half that long today.
    It was good stuff...in 1983's world
  14. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    Eaton aerospace/Aeroquip make some of the best hoses anywhere...including plain black rubber and black nomex cloth covered that are a near dead match for OEM. Or did you mean stainless braid with red and blue fittings as being low rider bling?
  15. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    The reason for specifying stainless braided hoses in some situations is that they are resistant to abrasion or physical damage. That means they are only appropriate where there is a risk of this happening, and this would not be the case (hopefully) when being used as replacements for rubber fuel hoses. They make sense as brake hoses as these are exposed to possible damage.
    They also have the drawback of the braiding hiding any underlying deterioration or cracking of the rubber.
  16. jdamon
    Jul 6, 2015
    288
    Boston
    Jeff
    So, are these more resistant to etoh? Or just good replacements that look like oem? Thanks!
