Hot air leaking in | FerrariChat
Hot air leaking in
Discussion in '206/246' started by raywong, Apr 21, 2015.
  1. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    Is it normal to have hot air coming from the handbrake ashtray saddle area? The faster the car travel the more hot air gets in. Is it the air that’s passing thru the radiator? or is it the coolant hose inside the saddle? Thanks for any advice
    Raymond
  2. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    Is air blowing in around the accelerator pedal?
    I'd check all the wheel well guards are installed, and the undertray is sealed tight (particularly at the front edge) and none of the hatches underneath are off.
    There was yellow packing around the tunnel openings under the consoles so you could unscrew the console sections and push some more foam packing around the handbrake etc.
  3. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,488
    Germany
    Matthias
    I had the same problem with one of my Dinos....
    If you open the window it gets even worse... like a hot fan blowing....
    With my Dino the underbody panel wasn`t sealed correctly....
    After closing all holes and gaps the problem was solved.
  4. swift53
    swift53 F1 Veteran
    8,336
    E.S.
    Alberto
    Matthias, is there something for the underbody panel to seal it correctly,
    or just rivets?
    Or are you meaning that before you apply the panel, you seal all beneath it?
    Regards, Alberto
  5. raywong
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    I just had a full restoration, we had changed all rubber seal of the spare tire tub and installed new underbody panels. Hot air used to come from the clutch and brake pedal holes before the restoration, now it is mainly from under the handbrake. I will try first to deal with the tunnel cover, hopefully no need to open the underbody trays.
  6. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    just rivets, but don`t leave any gaps open especially in the front and back
    put flexible body sealing between panel and frame
  7. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #7 synchro, Apr 23, 2015
    When they performed the restoration did they remove the fiberglas wool from between the tunnel spine and the floorboards?
    Might want to remove the gear shift console and have a look as this important and purposeful insulation.
  8. raywong
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    OK, we have stuffed up all the holes in the tunnel and sealed up the under body panels. It’s a hot summer morning and I went for a test drive on the highway, My cabin still gets very warm after half hour driving. The ashtray got really hot, almost as hot as the engine hood. The shift stick and gate also got quite hot. Basically all the expose metal in that area are hot, I can feel that heat radiation on my face. Is this normal?
  9. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    no, that`s clearly too hot....
