Hot Starter Blues | FerrariChat
Hot Starter Blues
Discussion in 'Boxers/TR/M' started by cryorunner, Jan 29, 2010.
  1. cryorunner
    cryorunner Karting
    Aug 11, 2009
    161
    San Diego, CA
    James
    Argh, for the first time ever my car let me down tonight.
    I thought I was better than everyone else, because while my starter solenoid would frequently threaten to act up when hot, it would always give in and fire after holding the key for a few seconds. Not this time. Stopped for gas, and knew it would give me a scare, with just the right amount of time for the engine bay to heat soak. But this time it decided to bite me, and it took about 25 minutes for it to finally give in. Opened the hood for a while, but not sure if it really helped.
    I'd read the threads before, so I guess I know my game plan and will read up on all the details, but still just had to vent. I'm not sure if it would have made a difference on this car, but I didn't even have anything heavy to bang on the solenoid. Have seen that work with other vehicles, usually when cold. But if nothing else it would have let me vent my frustration. I think I've got a brass hammer somewhere that I can take along to at least feel like I'm doing something useful while the thing cools down.
  2. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,023
    #2 2dinos, Jan 29, 2010
  3. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    I guess that might be caused by one contact making before the other. When the first contact makes there is no current passing. As soon as the second touches....sparks and spark erosion. Thats my theory anyway. 2Dinos, at least you are in there and able to sort the problem out once and for all :)
    P
  4. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    I think a cold rag would work better to cool it down vs. a hammer. The good thing is the solonoid is very cheap and very easy to install... Once you get that done you will have full confidence that when she is hot she will fire up.. Look up WIA Solonoid.. Should cost around $12.00 to $15.00.
    R
  5. blown daytona
    blown daytona Formula 3
    Feb 6, 2008
    1,679
    maryland
    +1 Just replaced mine a few months ago. Thanks to the resources here, I found a WAI, so cheap it cost more to ship it. Love using Chinese parts in an italian car :D
  6. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,023
    I had a very frustrating intermittent start problem with a Bosch starter on another Italian car. I rigged up a light to the starter circuit after I exhausted every other means to catch the gremlin.
    The problem: There are two sets of winding in a solenoid. One hi current winding to pull in the plunger, a second lower current winding to hold it in. The actual circuit can be seen on some starter wiring diagrams but typically is very small. As it turned out, the hi current winding had a defective solder joint. Took a few hours to fix because the car was not service friendly getting to the starter, but forever and a day to figure out.
    Thanks Philwozza. It's rewarding after the gremlins are put back in their cage:)
  7. sws4re
    sws4re Formula Junior
    Jan 28, 2006
    281
    Olathe Ks
    Scott Sweat
    I have put a high torque mini starter on a 512 and a dino. In both cars the owners loved the upgrade and have not had another problem. Both cars start faster than before and the good thing is if you want the original back in for a show, on the boxer its a fast swap back to the stocker.
  8. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Pull the "plunger" out of the solenoid and sand about .004" of material off the overall diameter, treat it with dry lube and reassemble. I think you will find that when it gets hot it will no longer bind in the bore. I believe this was done to my car for the previous owner, he was having the same issues. So far I have never had it hang up.
    Another Fchatter made one cut length-wise in the plunger and collapsed it slightly for the same result. Deburr the sharp edges and reassemble.
    I think both of these fixes are performed without removing the starter from the car.
  9. cryorunner
    cryorunner Karting
    Aug 11, 2009
    161
    San Diego, CA
    James
    Hmmm, I'd been thinking of having to mill 0.004" out of the bore, but it'd be a lot easier to sand 0.004" off the shaft instead, if it'll keep working. I was originally going to just replace it, but it seems really easy to get to and I probably owe it to myself to look at the existing one, which will be the weekend project.
    A few questions came up though:
    1) Is that WAI 66-9131 really the right replacement for my 0-331-303-032? It doesn't show as a cross reference on the WAI page.
    2) Is the WAI any better than the original Bosch at avoiding this issue, or would it need some more clearance too?
    3) What's the best way to acquire the WAI part (say online)?
    4) Is there any value in investing in the "premium" 66-9131-1 part?
    Also, is there anything special to bump-starting this car if it happens to me again? Without having looked at the wiring layout of the starter yet, is it possible to engage the starter by bypassing the solenoid by shorting out some of the terminals with something big and metalilc?
    Thanks again for all the great tips here.
  10. Steve Magnusson
    26,785
    1. I believe so (although I purchased the earlier 7-851). The photo of 66-9131-1 shows it has the correct small electrical terminals (15 and 50).
    2. My 7-851 has worked well (without modification) for 9 years.
    3. Your homework ;) (just find a WAI distributor)
    4. Even the "premium" part will probably be 1/5 the cost of the Bosch part -- so, if availability is the same for either, I'd get the 66-9131-1.
    You can push start a TR, but before resorting to that:
    gearbox in neutral, key "on", parking brake "on" -- touch that big metallic object between the "+" battery cable post on the solenoid and terminal 50 on the solenoid (where the white wire is attached -- which can be removed if that helps access). If your problem is a "weak" or "sticky" solenoid that should help engage the solenoid+starter just like putting the key in POS III.
  11. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,023
    This sounds like a great fix. I didn't notice any binding between the plunger and the bore. Was your plunger corroded?
  12. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    You probably won't notice any binding with "cold" parts.
    Did you test for binding when at the time of failure? (I know, hard to do stranded on the side of the road)
    I do not know if my plunger was corroded but it had been replaced at least once before and the problem continued on hot starts until this "final" fix. I believe the binding has to do with,
    A) The location of the starter on top of the engine and resulting heat soak.
    B) Different expansion rates of the plunger and the housing, the plunger expanding more than the housing.
    C) Heat soak affecting operation of the actual solenoid, reducing it's ability to move the plunger.
    I have heard of TR owners changing to a remote solenoid mounted on the LH inner fender using a Ford item but I don't believe that fixes the binding plunger issue (if any).
    I would measure the inside bore of the housing and outside diameter of the plunger to see if there is an issue before making mods. There may be a tolerance overlap under high heat conditions..
  13. EZORED
    EZORED Formula 3
    1,033
    Scottsdale, AZ
    Dennis
    Having had the same problem, I replace the starter and solenoid with the WAI unit. That fixed the problem for a short while, but it returned. I could engage the starter if I jumped the 2 terminals, This means that I am not getting enough voltage at the starter. I went to BAP autoparts and bought a starter relay (like in a ford) for about $35. I installed and no problems since.
  14. Steve Magnusson
    26,785
    I realize that you are happy with your "added relay" solution (and don't expect you to undo it), but it reminds me that there are other connections that can cause a voltage drop on the white wire (terminal 50) at the solenoid to be too low, and no one (including cryo) should buy a new solenoid until they confirm that the voltage on the white wire is OKish during a start attempt (like 8-9 volts minimum), but the solenoid doesn't still engage. This post shows the connections that should be checked/cleaned/measured in the food chain between the ignition switch (terminal 50) and the starter solenoid (terminal 50) before concluding you need a new solenoid:
    http://ferrarichat.com/forum/showpost.php?p=138889675&postcount=7
  15. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Thanks Steve,
    I have no doubt that I may have to refer to this process in the future.
  16. cryorunner
    cryorunner Karting
    Aug 11, 2009
    161
    San Diego, CA
    James
    I know Steve, I already had at least one of your starter food-chain posts archived and it was certainly on my mind to want to see the voltages back there, but unfortunately this failure is most likely to happen at inconvenient times instead of in the garage! The other night at the gas station I didn't have anything with me, or a second pair of hands to help, but now I'll at least leave a DVM in the car and some copies of the wiring diagrams. I'm going to at pull my old solenoid and likely just buy a WAI one if I can get it for ~$20, as this looks like a very accessible part (famous last words) and I want to become more familiar with the layout so I'll be more prepared next time to do some diagnostics.
    Since the scares the starter has given me before have all be related to high engine compartment heat with the car parked for only a few minutes, I'd at least assumed it would be a good bet it's the tight solenoid issues that I had read about. Although I'd been curious about voltage supply in the past, as the fans are generally running when it's threatened to be bad, in this first case of full failure engine temps weren't hot enough to trigger the fans. Oh, and in this case it really was about 20 minutes of cooling that did the trick and it started on its own.
    Thanks again for the great guidance here on this and 1000 other issues!
  17. cryorunner
    cryorunner Karting
    Aug 11, 2009
    161
    San Diego, CA
    James
    As a possibly unrelated thought here, brought up by a friend of mine after talking about my solenoid:
    Has anyone ever thought about or experimented with putting the fans on an unswitched circuit as they seem to be with modern cars? I'm not even proposing that as a real solution to this particular issue, but just wondering whether the extra air being pushed through the engine compartment for some arbitrary time after the engine was stopped would be helpful. I've never measured anything, but I'd venture to guess that right after parking a hot engine might yield some of the hottest temps that engine compartment ever sees under normal driving. Maybe it could be beneficial in other ways, like for the cat temp ECU's, which I'd assumed fail due to the high heat in there. Looks like the starter solenoid is taking most of its heat from cylinder #7, followed by all those exhaust parts, so don't know how much air flow would really make it back there.
    Still haven't had a reason to look where the temp switches for the fans are located, so I don't know how long it would really take for them to shut off WITH the fans running (but no fluids flowing). I do know they can still be on quite a few minutes later if I come back to the car, but this is with the fans off.
    I'd be curious to know what the results were if anyone has tried this.
  18. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I have my truck wired directly off the battery through an adjustable rheostat. The cooling fan will continue to run after the engine is shut off to reduce the amount of "purge" from the radiator.
    Once the engine is shut off there is no water circulation so, yes, the temps take a hike. Air passing through the engine compartment helps with heat soak. This is also why I open the rear hatch on the TR when I stop after a long run or city driving, to lower the temperature back there.
    Don't forget, the exhaust system is adding to the heat build-up as well.
  19. cryorunner
    cryorunner Karting
    Aug 11, 2009
    161
    San Diego, CA
    James
    #19 cryorunner, Feb 16, 2010
    Since I was in working on my starter solenoid (Bosch 0 331 303 032) I took some pictures for reference. Figured I'd post up something for those like me who'd never taken the thing off before. This is pretty basic stuff, so for anyone who's already worked with this part there's no point in wasting time looking at this. But for someone clueless like me, who didn't even know where the part was located on the car, it might help. Also a good thing to know the location for other diagnostics, such as Steve M.'s great stuff which frequently references solenoid terminals.
    [Double check you've got the battery disconnected]
    The starter solenoid is located under the air filter, on the left hand side (see pic #1 looking from the left rear of the car). You won't need to remove the starter or the air filter assembly to get it out.
    It can be removed via 3 Phillips #2 (I think) screws, 2 shown in the pic and one pointed to by the screwdriver. Before actually removing the screws I would suggest first cracking the 13mm nuts on the two large posts first, so you've got a more stable frame to torque against. You'll need to remove the red protective plastic piece to get to these nuts, and will probably have to remove the top blade connector to get it off.
    If you remove the left thick cable (12V) from the solenoid first it will make it much easier to pull the body off. There will be a spring inside (see pic #2) so don't lose it.
    The solenoid piston is hooked onto a lever arm in the starter, so in order to remove it you'll need to tilt the piston all the way to one side (see pic #3).
    To reassemble:
    You'll need to align the tab on the back of the solenoid piston vertically so that the arm from the starter (pic #4, looking from the front of the car) can be engaged through the slot on the tab (see pic #5, view from above). When you reinstall it you'll have to tilt the piston as in pic #3, and when it's properly engaged you'll feel that you can't pull it out when aligned straight. For me it was easier to place the spring in its slot in the solenoid body before reassembling. And again it's easier to re-torque the nuts for the power cables with the body reattached.
    That's it. Pretty simple stuff and the only tricky part is knowing how the piston is attached to the arm from the starter, but once you've seen what it looks like inside it's trivial.
  20. cryorunner
    cryorunner Karting
    Aug 11, 2009
    161
    San Diego, CA
    James
    OK, so after working on the solenoid and getting a few drives in I think I'm ready to declare success so far. I've made it a point to get it into lots of situations where the engine would get hot and certainly would have threatened to stick and given a long delay before engaging. Now it starts instantly.
    What I did was remove 0.001" off of the diameter on the solenoid piston, as suggested in another thread and by Spasso in this one. I went with less machining than suggested as the existing piston clearance seemed to be ~0.001" (didn't get a precise measurement on the ID of the body) so this would be doubling the existing clearance. I figure I can always make it smaller.
    Here's what I did:
    - Chucked the piston in a power drill holing onto the tab, and set it on its slowest gearing.
    - First used 150 grit sand paper to remove 0.0007" this happened FAST even on the slow setting of the drill.
    - Then "polished" with 600 grit paper to end up at 0.001" (see measurements below). The resulting finish was probably a little smoother than the original.
    - Sprayed a layer of graphite dry lube on the fresh surface so it wouldn't look so much like it would want to rust.
    Before machining it down the piston diameter measured between 1.0605" - 1.0608" (six measurements, parallel and perpendicular to the tab at three locations along the piston). After my "machining" the piston diameter measured 1.0596" at all six locations. The approximate ID of the bore of the solenoid body, taken using a locked pair of calipers as a make-shift bore gauge, was 1.061(7)", but this was a sloppy measurement.
    I'm not trying to propose this as a solution for anyone else, it's just what worked for me (so far, knock on wood). Certainly not a substitute for a solid diagnostic of the whole system as suggested by Steve M. here and elsewhere. I went this way as opposed to replacing the solenoid mostly because I was worried that I might have the same issue again, even with a new Bosch or WAI unit; I wanted to try to do something specifically to address my symptoms of getting too tight and sticking when hot. This is certainly a big, big improvement in my case.
  21. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    .....nicely done !
    Have you done the "relay" mod to the starter yet?
    Shamile
    Freeze....Miami Vice !
  22. cryorunner
    cryorunner Karting
    Aug 11, 2009
    161
    San Diego, CA
    James
    #22 cryorunner, Feb 17, 2010
    No, not at this time.
    First this was more of a fact finding mission here; I figured after removing it at least now I'll know where all the relevant terminals are so I can do some diagnostics, and while I had it out I could try out a fix that seemed to fit best with my symptoms.
    Second, I agree with Steve M. that it's worth looking at the path all the way to terminal 50 and understanding what's going on prior to adding anything. At least now I know where some of this stuff is, and will have some equipment with me next time it fails! IF it gives me trouble again, now I can look at the voltage at terminal 50 and see if it's "low" and try just shorting it out to the 12V terminal and see if it starts it.
    If that were the case I'd have to make some decisions about an external relay. In general I'd be reluctant to stick more electronics in that hot engine bay, but maybe that'll eventually be what happens. But I would rather ensure that there's minimal voltage drop towards terminal 50 and ensure that the solenoid is working as it should at all temps.
    For now I'm just hoping that this fix sticks!
  23. David Lind
    David Lind Formula 3
    Nov 19, 2008
    2,248
    David Lind
    I couldn't get the WAI website. Does anyone know where to get Bosch solenoid # 0331 303032?
    THanks!
  24. David Lind
    Nov 19, 2008
    2,248
    David Lind
    Actually, I could find the website but couldn't find the Bosch part within that site. Any ideas?
  25. Mr.Chairman
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Check the cross reference thread.. there is info on distributor for WAI solenoid.. WAI is the way to go.. Have mine in a long time and never had a hot start problem resurface..
    R
