How about 550 throttle body on 348 project? | Page 2 | FerrariChat
Discussion in '348/355' started by fatbillybob, Jan 16, 2007.
  1. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    You stooges are crazy. Can you just finish the 355 tbs project first?! Personally, while I like keeping it Ferrari, the Corvette/Mustang parts on 550 tbs sounds just too interesting. Son of FrankenFerrari!
    BTW, forced induction is so much less complicated. :D
  2. group77racing
    group77racing Formula Junior
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    There are no bowtie nor blue oval parts on this project. All bosch components with hand fabricated assemblies. I should have the injector boss' welded in, fuel rails mounted and throttle linkage completed by the weekend.
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Yeah, Baby! Time for some testing!
  4. plugzit
    plugzit F1 Veteran
    7,792
    Redondo Beach, CA
    Bruce Bogart
    If we did that, then we wouldn't be stooges would we?
  5. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I don't even have a 348 and I've subscribed to this outfrickenstanding thread.
    I'm learning a lot - You guys rock.
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    Have you seen these injectors
    http://cgi.ebay.com/ebaymotors/Mototron-60-Injectors-1995-2004-Cobra-Camaro-Corvette_W0QQitemZ140085789790QQihZ004QQcategoryZ33554QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    These are 60lb I bought for my blower motor, but I'm pretty sure they come in lower flow too. They have a really small OD so they can be mounted at a better angle....at least that's what I'm thinking. The OEM QV intake had a curve so the injector could spray right at the valve, but my runners, like yours, are now straight making hard to get a good injector angle.
  7. group77racing
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    #32 group77racing, Feb 17, 2007
    couple pics of injector bosses welded in, fuel system mocked up, and cam- cover breather system with drysump breather on right. Intake goes to coatings on monday, along with some exhaust parts. The breather cans look too high and too big because of the camera. They are perfect size and neatly out of the way. The stock airbox mounts will be removed and relocated further rearward to put the modified stock box where the upper muffer use to be.
  8. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    It's coming along.
  9. plugzit
    plugzit F1 Veteran
    7,792
    Redondo Beach, CA
    Bruce Bogart
    Awesome job. Can't wait til it's running. Wish I could be there to see, hear, learn, and ride.
  10. Andy hls
    Andy hls Formula Junior
    Dec 17, 2003
    653
    Kent UK
    Andy
    Dave it all looks very good,my only concern is that your catch tank for the oil is over the top of your right exhaust,i had something very similar to your one, i am on my 3rd breather design at the moment, as on the track it must build huge presure because it blows oil out of the filter at the top,i dont want anything to happen to that lovely engine.
    Sorry if you already have it covered just checking.
    Andy.
  11. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    NOW THATS WHAT I'M TALKING ABOUT DAVE!!!!!!!!!!!!!!!
    For those of you that haven't noticed, have a look at the plenums on the 430, they are designed pretty much the same way Dave has his.
    Eventually I think I'm gonna end up with something like this one my car.
    I love being a Stooge.
  12. group77racing
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    The exhaust on this 348 is fabricated to enter the custom X-muffler at the bottom, so interferance is not an issue. Also, drysump engines scavenge more oil than they pump, so there is a negative pressure in the crankcase thus pushing the excess scavenged air into the drysump tank. My catch can is just high enough so the oil shouldn't be pushed into the can. Also, if the drysump tank is too full of oil, it will always push oil out. thanks Andy
  13. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Any pics of this?
  14. group77racing
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    #39 group77racing, Feb 23, 2007
    Got the ceramic coated parts back today. Still have some final details to finish. It should go back in the chassis next week. Then I have to mock up the airbox and send that out for Powdercoat. Still waiting for the bodyshop to get my bumpers and rear deck back to me. Also have to finish the custom brake conversion.
  15. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Looks kick ass!!! :D :D :D
  16. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    I'm ready for the road test!
  17. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    So what is the latest?? :)
  18. group77racing
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    #43 group77racing, Feb 25, 2007
    Well, hooked up the IAC valves and plumbing. Ran the new harness for the dual A/F monitor. changed fuel filters on the chassis, then discovered a factory flaw. The pressure lines from the pump to the bottom of the filter have to be upgraded. Did you ever look inside the 90 degree fitting on the bottom of the filter. Its very small, the smallest orfice on the entire fuel system. So, I'm going to get 4 (2 for each side) metric to -6 adapters, four AN 90's and make my own feed lines. I can't believe the short, small abrupt 90 on the factory feed line, its worthless. Stock ID for supply fitting is .185 about 3/16. The fitting ID on the fuel filter is .230 about 1/4. The AN -6 fittin ID is .293 just unter 5/16. A .185 hole can't support much HP. The pump volume is fine, just trying to stuff the fuel through a straw. I build all my tuner cars with a minimum of AN-8 hose for naturally aspirated and AN-10 for forced induction. So, that gets done this week, and the motor goes back in this next weekend. Some airbox fabrication and I'll be good to run. Still have to finish big brakes and get bumpers back from bodyshop. Can't drive until all this crappy salt is washed off the streets. Usually be end of march first part of April, off to the dyno.
  19. fatbillybob
    Aug 10, 2002
    29,260
    socal
    What do you think is coming out of the fuel pump!
  20. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    One would have to have a fuel pressure gauge to look at while at full throttle on the dyno??? This would be something good to know/do :eek: making sure we have good fuel pressure under load @ full throttle!
  21. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Well son-of-a-gun! So are you putting the new fittings on the existing lines, or are you gonna run new lines, with the new fitting on them of course, from the pump to the filter?
  22. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Fatboy has some on his ride. It would be interesting to see what the pressure is a WOT.
  23. group77racing
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    #48 group77racing, Feb 27, 2007
    You will loose your fuel volume before you start loosing pressure on a guage. Anyway, the stock feed line is just that, stock, for a stock engine. My engine is not stock nor is the fuel injection system. I'm just relaying my findings and fixes. The bottom pic shows the connection between the fuel filter inlet and the feed line from the pump. The stock 14mm threaded filter fitting has a .235 hole, the stock fitting on the feed line has a .185 hole !! The new setup has .297 hole thru the fitting and .271 hole modified into the -6AN fitting. The middle pic shows the connection between the fuel pump outlet and the fuel pump feed line. The stock 12mm threaded fitting has a .230 hole, the stock fitting on the feed line has a .250 hole. The new setup has .297 hole thru the fitting and and .271 hole modified into the -6AN. The fuel pump outlet bore is .275. Simple and effective.
  24. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Where can I/we get our grubby hands on this setup/upgrade??? :eek: :D
  25. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Yeah, what he said.
