How about 550 throttle body on 348 project? | Page 3 | FerrariChat
Discussion in '348/355' started by fatbillybob, Jan 16, 2007.
  1. group77racing
    group77racing Formula Junior
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    http://www.pegasusautoracing.com/reviewcart.asp
    the link above is already filled out, just order the stuff at the check out.
    The driver side (USA lefthand drive) hose assembly uses 2- 90 degree -6AN fittings. cut the new -6An hose to 15 inches. The passenger side (USA lefthand drive) hose assembly uses 1-90 degree -6AN and 1-45 degree -6AN fitting. The 45 degree goes to the fuel pump outlet. Cut new -6AN hose to 17 inches. Assemble hoses. Get a .297 drill bit and drill out the 12mm adapter fitting the rest of the way through. Just do it. Drain tank, remove stock feed lines, remove stock fittings,one on inlet of fuel filter (bottom one) and one on fuel tank( pump outlet). Then inpect inside pump oulet port with a light to chech for debris before installing new fittings. The 14mm fitting comes with a seal, the 12mm fitting you will need to new copper washers. Then install new fuel lines, 15 inch on the left and 17 inch on the right, make sure the 45 degree fitting goes to the right tank pump outlet, checking for correct routing and clearances so the AN hose ends are not hitting anything.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Coolness, thanks Dave.
    This is definately on the to-do list.
  3. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Yeah thanks !!!! :)
  4. fatbillybob
    Aug 10, 2002
    29,260
    socal
    Dave,
    Do you know if you have to drain the tank to get the fuel pump out of the tank so you can change the internal check valves?
  5. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    Looks awesome! :):):)
  6. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Has the tunning commenced?? :)
  7. mad dog
    mad dog Formula Junior
    Jan 5, 2006
    875
    suffolk uk
    andrew
    Which sounds fun, but what would it do? What are the check valves and change for what?? So many questions, so short a time..
    As you gather I havent a clue what you are talkign about, but like to learn..
    ta
  8. group77racing
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    Its going back in tomorrow, then I still have to fabricate and mount an airbox, finish welding the custom muffler system, finish the custom brake conversion. At least the brakes are almost done. Just got done cutting off the stock airbox mounts from the chassis, and touching up the paint.
  9. group77racing
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    #59 group77racing, Mar 3, 2007
    Ok, its in! Left to do.....final welding on muffler assembly, throttle linkage, airbox mod, airbox mount, fluids. Then I can run it. Have to finish brakes, mount both bumpers, rear engine bonnet and wait for rain to wash the salt mess off the streets. Just another winter day in Wisconsin...
  10. TexFerrari
    TexFerrari Formula 3
    Sep 11, 2004
    1,194
    Texas of course!
    OMG, that looks so nice! I hope this works out well on the performance side. Someone was supposed to make some 348 headers, going to check back with them, could be a little more on the table there! Have you considered using the carbon canister filters instead of the stock box?
    When your done, sense you like tinkering, want another 348 to work on? I'll have to send you another one ASAP!
    So now we have this one, the one with 355 intake and Andy’s with the ITBs! Anyone know numbers on the other setups yet?
  11. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    I love it!!!!
  12. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Andy is making 400+, and Plugzit is a bit under 355 power, but he still has to fine tune it more.
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,807
    The twilight zone
    Did these guys FINALLY get these cars on a dyno, or are the numbers still conjecture?
  14. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Well, Andy has done a pull on the dyno but hasn't put the sheets up. He did say that it did put down 400hp without squeezing the bottle.
    Plugzit, was using a G-tech. Yeah yeah yeah I know, they aren't accurate for power numbers. But what he did was run a base line with it, and then after each ecu mod. We also had gothspeed do a few runs with the G-tech in his car so that we could compair the numbers.
    It will be interesting to see what these actually put down.
  15. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    :eek: 400hp on a 348??? What has Andy done to his car?? Is that the aluminum velocity stack, individual throttle body monster I have seen around here??
  16. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Oh man that looks nice. Watch out 355ers! The air collector atop the tbs' looks like it might be a sticking point. Will it flow as much as it needs to at normal aspiration?
  17. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Very impressive and well thought out fabrication --a work of art.
    Looking forwardto the dyno numbers!
    Good luck and congrats on a beautiful job!
  18. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Yup, that's the one.
    Here check it out, but try not to make a mess all over yourself. It is a thing of beauty.
    http://ferrarichat.com/forum/showpost.php?p=136449522&postcount=47
  19. DMOORE
    DMOORE Formula 3
    Aug 23, 2005
    1,720
    San Diego
    Darrell
    400hp from a 348! Thats it! I need some turbos on the 355. 7 PSI should do nicely.
    Darrell.
  20. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
  21. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    I'd be happy with even 2 PSI !!! ;)
  22. group77racing
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    #72 group77racing, Mar 7, 2007
    OK, today got the modified airbox back on, throttle linkage done, IAC valves plumbed, TPS set, AMM Ohms set. Still have to do rear brake brackets, mount rear bumper, to align and tighten exhaust. Mount rear deck, front bumper, lights, grill etc. Numbers will come as soon as the weather breaks and the roads are salt free.
  23. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    That's a great look. Can you please elaborate on the larger MAFs? What did they cost? Do they output the same signal as the stock units?
    Is your engine running as you've got it set up today? If so, what process did you go through to set the ohms on your MAFs and what is their current ohm value?
    Do you have fuel pressure and fuel flow values in hand yet?
    Thanks for any help.
  24. fatbillybob
    Aug 10, 2002
    29,260
    socal
    Now that the oem airbox is out of the way. Do you have room for a strut tower brace? Also, it looks awesome except the use of the old airbox. It would have been cool to pipe cold air into individual small round filter/boxes right into the AFM's. The oem corrigated air pipes and airbox are not much to look at.
    So what did you use as the TB's?
    From what car or what maker and size?
    What injector size are you using?
    What engine management are you using?
  25. group77racing
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    I like the modified 348 airbox, its alot of work to re-shape it yet it still looks factory, I looked into the other set-up you described and drew up an aluminum pressure box but the factory airbox look keeps 'em guessin'. It would have been no challenge to just throw on a pair of BMC fiters, anybody can do that.
