How accurate is parts store test equipment | FerrariChat
Discussion in 'Technical Q&A' started by 50hdmc, Mar 2, 2010.
  1. 50hdmc
    50hdmc Formula 3
    Oct 10, 2006
    1,211
    Michigan
    mark s
    Some of you are aware of my accident a few months ago where I hit an animal with my 348. There was some lower front end damage and the car lost power (battery) and had to be towed. Once at the dealer they diagnosed the problem as a defective alternator and battery. As many of you know they wanted $5700 to update my delco alternator to the Nippondenso.
    The paint work was done and I had the car towed back to my home. I pulled the alternator and battery out today and took them both to Auto Zone where they tested both and said they were fine. So, I then went on to Oreilllys and had the tests repeated - they also said both were fine. My question is, how reliable is the test/equipment at these stores? Is the Ferrari dealer doing something more to determine the condition of these parts? Where do I go from here?
  2. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    How accurate? Hard to say but good tools in the hands of the untrained? That's an easier one isnt it?
    What are your symptoms?
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    There is absolutely nothing "exotic" about the alternator in your car. Other than the pulley it is very similar to ones on many GM cars. I've had them rebuilt, new regulator, bearings, etc. $89 my cost.
  4. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I had both alternators o my BB512i rebuilt at a local auto electric shop for $125 each...
  5. 50hdmc
    50hdmc Formula 3
    Oct 10, 2006
    1,211
    Michigan
    mark s
    I don't mind having it rebuilt at all, if that is what it needs, but it tests ok........I am wondering about the "bullet" type cable connectors now.
  6. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    I wouldn't doubt the store's testing equipment. The only thing an alternator can do is supply a charge. If it's good, it'll supply the proper amount of power (usually at, or a bit over 13.5V and whatever amps it was rated for [see your owner's manual]). If it's not good, it won't do either (or both) of those two things. Same thing with the battery, it'll either hold a charge (and keep it with a load on it), or it won't.
    As for the cost, wasn't that a recall item (alternator) with the 348 and should be covered?...
    I can understand that some Ferrari parts are justifiably expensive, but this deal seems to be a cash-grab to me...
  7. f355spider
    f355spider F1 World Champ
    18,052
    The equipment should be plenty accurate...but....A friend with a 348 had a charging problem with his ND alternator. It had been rebuilt once previously, but started intermittently blinking the "batt" light. He pulled the alternator and had it tested at a couple places...and both said it was fine...yet when he put it back in the car, he would still get the "batt" light once in a while, and once, it left him stranded, though a jump start got him home.
    He pulled it out again, and this time took it to Romaine Electric, a large shop that rebuilds alternators for many independent shops. They ran it on their test equipment and initially it tested fine too...then they left it running on the bench for 15+ minutes and then, the voltage regulator failed. They shut it off, and let it cool, and started it up again, and it ran perfectly. It just failed intermittently when hot.
    Just goes to show...HOW you test is important as well.
  8. 50hdmc
    50hdmc Formula 3
    Oct 10, 2006
    1,211
    Michigan
    mark s
    ...thanks Hugh, good point! I am a little less than trusting of this dealer. When they picked my car up and towed it in they wanted $175. When they brought it back they wanted $289. Said they had a price change during the interim period.
  9. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Huh? WTF? That's not an endorsement :)
  10. 50hdmc
    50hdmc Formula 3
    Oct 10, 2006
    1,211
    Michigan
    mark s
    ..I didn't intend it to be a endorsement.....just a word of warning for those who live in my area of the country.
  11. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    About 8 years ago my BB512i started running hotter than it had been running...~100c verses the 85-90c it had been running. I went through several repair attempts to no avail. Finally, a friend asked me had I checked the alternators. While I thought that was odd,I stopped by an Autozone and had them do a free check on the charging system and it failed. I had both alternators rebuilt at a local auto electric shop and the temp went back down to 85-90c. It seems that the alternators were not putting out enough current to run the cooling fans at full speed which was causing the higher temperatures. So in my instance, the Autozone test equipment did work.
  12. twright
    twright Karting
    May 15, 2005
    225
    Indianapolis USA
    Its easy to check the alternator yourself: With the engine off, measure the voltage at the battery. It will be 12-12.5 volts. Start the engine and rev the engine a little (above 2000 RPM). Measure the voltage at the battery again. The voltage (with the engine running) should be 1.5-2.0 volts higher that the engine off reading. If it's not, you have a problem and its probably the alternator, voltage regulator or some wiring glitch.
  13. Fleming
    Fleming Rookie
    Mar 6, 2010
    3
    I would say accurate.
  14. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    took my battery to auto zone to be checked. the man said dead. took it to advance. the man said good, needs recharge. very definitive.
  15. 50hdmc
    50hdmc Formula 3
    Oct 10, 2006
    1,211
    Michigan
    mark s
    In the end, the alternator and the battery that the dealer said were bad turned out to be fine...both of them!
  16. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,605
    San Carlos, CA
    Mitchell Le
    time to avoid the dealer, then. Which one is it?
  17. 50hdmc
    50hdmc Formula 3
    Oct 10, 2006
    1,211
    Michigan
    mark s
    ..it is the only Ferrari dealer in Michigan.
