How am I getting a Slow Down light?!?
Discussion in '360/430' started by RedNeck, Jun 19, 2017.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. RedNeck
    RedNeck Formula 3
    2,078
    TN/GA
    Matt
    Ok, I started my car today..immediately greeted with an amber blinking "Slow down". Turned the car off for a few minutes, restarted, everything ok. Drove for about 2-3 miles, and greeted with the steady "slow down". Turned car off, restarted and drove home with no other issues.
    I have aftermarket cats and my temp monitoring has been turned off, according to my PPI last year. How in the world am I all of a sudden getting the stupid light?
  2. vrsurgeon
    vrsurgeon F1 World Champ
    10,596
    Charleston, SC
    Curt
    Bad vesicovini box (temp thermocouple ecu). If it has no temp ECUs.. then whatever they did is ****ing up. Simple as that. Look under the engine panels...
  3. HIO Silver
    HIO Silver Formula Junior
    Mar 12, 2016
    434
    Northern California
    Alonso C.
    01 360 Spider
    .. happened to me too.. intermittent problem. I bit the bullet and, not knowing which was bad, replaced both thermocouple ECUS (signal data converters) and no more slow down light.
    Dunno about the aftermarket cat mod but sounds like your ECUs are missing a signal.
  4. RedNeck
    RedNeck Formula 3
    2,078
    TN/GA
    Matt
    I also made the horrible mistake of not having the battery on the charger for exactly 1 night. Could it also be another temper tantrum due to that?
  5. Shinigami
    Shinigami Formula Junior
    Rossa Subscribed Owner
    Aug 2, 2005
    283
    Gland Switzerland
    Heikki
    I also had the ECU/box thing go bad. Developed a crack at one plug-end. Dealer replaced free of charge as I had bought the car second hand from them.
    I can leave the car sitting a week and it starts up just fine, you would have to have a failing battery if it required the trickle charger every night just to run fine the next day. I believe some have mentioned their car firing up just fine even if it sits a few weeks.
  6. Mikael-F360
    Mikael-F360 Formula Junior
    Apr 3, 2017
    400
    Finland
    Mikael E.
    Same here. I have left my car sitting in the garage for a few days with no problems. Perhaps a good time to change the battery to a lighter one for weight savings.
  7. Tired of seeing this ad? Upgrade now
  8. RedNeck
    RedNeck Formula 3
    2,078
    TN/GA
    Matt
    Ill check the ECU's but the battery is less than a year old....o put ot back on the charger so Ill try to take it out again.
  9. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    2,780
    Southern California
    Jes
    Not if your battery is decent.
  10. f355spider
    f355spider F1 World Champ
    May 29, 2001
    15,492
    Seattle, WA USA
    Hugh G. Rection
    Unlikely. Catalyst ECUs issues and bad thermocouplers are a common problem. I replaced at least two catalyst ECUs during my 10 year ownership of my 355. There are plenty of threads here on how to diagnose both components and determine which is defective. You should own an OBDII scan tool. Ebay has them for cheap. I have a ELM 327 scan tool with Bluetooth connection to my IPhone. I downloaded an free app for my IPhone. Works great. Cost all of $10 or so. Scanning codes can assist with narrowing which side is bad....then by swapping components left to right you can see if the problem moves.
  11. RedNeck
    RedNeck Formula 3
    2,078
    TN/GA
    Matt
    I have one....somewhere
