How an engine block? | FerrariChat
Discussion in '308/328' started by bvdp, Jul 2, 2017.
  1. bvdp
    bvdp Karting
    May 30, 2007
    65
    Belgium
    Bart vdp
    #1 bvdp, Jul 2, 2017
    I have an alternator problem on my '84 308 GTS QV. As I wanted to do a timing belts change coming winter, I want to do it also now, together with the alternator build out/in. No problem so far as these two operations are well documented on this forum.
    I also have a small oil leak on the sealing of the crankshaft head and want to replace that sealing. To do so I have to get the pulley off and to do so the 36 mm headed bolt. Anyone an idea how I can block the engine to loosen the large bolt on the crankshaft? Modern cars usually have a (special) way to do so but, as you all know, a 308 is an old car and on top of that not designed to work on :).
    Regards, Bart
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,570
    San Carlos, CA
    Mitchell Le
    1/2 inch ingersol rand impact wrench.
  3. bvdp
    bvdp Karting
    May 30, 2007
    65
    Belgium
    Bart vdp
    Thanks. Thought about that. Not a problem for the crankshaft bearings?
    Besides, the bold on a crankshaft usually is hard to get out. Needs a lot of torque so a way to block the engine would be nice to know.
    Bart
  4. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
    Stick it in gear
  5. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    Agreed - use 5th gear, then (since the wheels will be off to get access to the front of the engine) have another person sit in the drivers seat and press the brake pedal while loosening the bolt.
    The force of the brakes, combined with the mechanical advantage of the high gear, will provide more than enough resistance to prevent the engine from turning while trying to loosen the bolt.
  6. bvdp
    bvdp Karting
    May 30, 2007
    65
    Belgium
    Bart vdp
    All the torque will be on the gearbox. Is that no problem? Don't want a tooth of a gear to brake :).
    Bart
  7. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    California SF bay area
    Paul
    You don't need to block the engine when using an impact gun. The short duration and rapid repetition of the impacts will not rotate the mass of the crankshaft, rods and pistons. The same reason an impact wrench doesn't try to twist your arm off when you use it.
  8. bvdp
    bvdp Karting
    May 30, 2007
    65
    Belgium
    Bart vdp
    I know. Tried one today but no succes. To little torque to get the bold out.
  9. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    Rather than an impact gun, is it possible to get a long breaker bar on the socket to get leverage (again using the brakes and transmission in gear to hold the engine).
    Alternative proposal - I don't know if this is common in the Ferrari world, but in the Mazda Miata world it works great - let the engine starter do the work.
    Determine the direction of engine rotation, it is clockwise when looking at the front of the engine through the wheel well. That means that if you put a socket wrench with the socket on the crankshaft bolt, brace the handle of the socket wrench against the chassis member or suspension arm rearward of the crankshaft pulley, so that the wrench against the suspension arm resists the rotation of the wrench along with the crankshaft - by using the starter to turn over the engine, the stationary socket wrench will back out the crankshaft bolt. You don't want the engine to start, just to rotate even one quarter of a turn to loosen the bolt. As long as your timing belts are in place, there's no harm in turning the engine over by one revolution even with cooling system etc. drained.
  10. bvdp
    bvdp Karting
    May 30, 2007
    65
    Belgium
    Bart vdp
    Used a stronger impact gun. Piece of cake :)
    Thanks.
    Bart
