How bad are these compression numbers? | Page 2 | FerrariChat
Discussion in '348/355' started by Copperhed51, Feb 22, 2023.
  1. Tarek307
    Tarek307 Formula 3
    1,349
    Long Beach, CA & Alexandria,Egypt.
    Tarek Salah
    If they are telling you they will increase the price by $5k if you do another test, definitely walk..thats not very ethical..or tell them hey, ok then if its another bad test you guys decrease the price by $25k lol.
    I think i know the car you're talking about 12K miles Red F1 with accident...
    tres55, carguyjohn350 and IvanRico like this.
  2. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,467
    Los Angeles
    Ah, that makes more sense. On top of everything else, $5k is not nearly a big enough discount for a low-compression engine!
    Tarek307 likes this.
  3. ClydeM
    ClydeM F1 World Champ
    12,201
    Wayne, NJ
    Clyde E. McMurdy
    +1 on this. I've tried a Harbor Freight and several others. HF got returned an hour later. Dont buy cheap tools. Not even for minimal usage. Your knuckles will thank you and you'll use less migrain medication.
  4. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    559
    Tempe
    Jon
    Typically want to see less than 10% of difference between the four cylinders on one bank. Number can vary per gauge as has been reference and if cylinders are wet versus dry.
  5. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    My HF leak down tester works great. All my cylinders show 680psi, so really healthy. :)
    Sent from my SM-G990U using FerrariChat.com mobile app
    INRange and GatedF355GTB like this.
  6. SethP
    SethP Karting
    Jul 2, 2014
    89
    Corning, NY
    Seth Parks
    I'm sorry but that mechanic should not be paid for his time if he is using a HF gauge and giving you those results. That is not a professional tool and does not produce professional results or even remotely accurate results for that matter. If he didn't realize that something was wrong with his process or tool then I would not trust his work.
  7. fatbillybob
    Aug 10, 2002
    29,380
    socal
  8. Shark01
    Shark01 F1 Veteran
    Jun 25, 2005
    6,596
    Yeah, this is a good lesson from the PPI 101 course I took….only use brand knowledgeable professionals with good tools.
    No harm, no foul in this case…..and I bet the prospective buyer ends up happier.
  9. tres55
    tres55 F1 Rookie
    3,573
    Canada
    The fact they're relatively flat across the board makes me think the gauge is ****ty. The variance between the cylinders is pretty tight.
