How can I reduce HC emissions on a 308 Engine - even temporarily? | FerrariChat
Discussion in 'Technical Q&A' started by tomoshea, Nov 27, 2004.
  1. tomoshea
    tomoshea Formula Junior
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    Hoping someone out there ahas some words of wisdom!
    I have a 79 308gt4 which recently has had a full carb rebuild.
    I have both banks running at about 3% CO +/- 0.5% no smoking, no backfiring running smooth.
    However I cannot get the HC numbers below 1400ppm on both banks!!
    The problem I have is that I need a max of 1200 PPM to pass the UK emissions tests.
    This is a UK car with none of the emissions gear on the US spec cars.
    I have heard that by adjusting the engine timing that it is possible to knock up to 300 - 400 PPM off the readings - but the car will run like a dog (I presume this is early ignition so that you get a longer burn in the cylinders?)
    Does anyone know if this is true?, or does anyone know of any better way to resuce the HC numbers at least just for the test so I can easily set the engine back up propoerly again ?
    I am going to recbuild the heads in a few months but I need to get the car through the test first.
    the car has 70K on the engine so I am assuming that part of the problem hear is wear in valve seals/ thimbles etc?
    All help welcomed?
  2. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    a temp fix is to lean the carbs out 1 or 2 turns
  3. tomoshea
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    I Tried this does not seem to make any difference?
  4. matteo
    Aug 1, 2002
    13,748
    Heir Butt
    does you car have an airpump?
    I have heard people would add peroxide in the gas tank but I don't know the full effects.
    Try a couple of more turns. My old carb car was leaned out so much i sounded like it was going to stall
  5. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    You refer to a valid idea, but have interpreted it in the wrong direction!
    Try RETARDING your timing by up to 10 degrees. note that the US cars have dual points so you run 10 degrees retarded at idle. This will help a catalyzed car in two ways, one being by keeping the exhaust gas temp up to keep the cats lit off, and the way it can help you as well is by heating the exhaust pipes up more and getting what's known as "post-flame oxidation". i.e. burn off the remaining HCs in the exhaust! Note that this isn't the same thing as dumping fuel into your exhaust and melting it down...
  6. Steve Magnusson
    26,573
    Another option (although not that easy) is to advance the exhaust cams by ~14 deg of crankshaft rotation (7 deg of camshaft rotation) to the US spec which closes the exhaust valve before the intake valve gets too far open -- i.e., helps prevent the incoming intake (unburned HC) charge from "leaking" into the exhaust system during the overlap period when both the valves are partially open.
  7. ham308
    ham308 Formula Junior
    Nov 3, 2003
    358
    NE Switzerland
    Richard Ham
    If you've got the carbs leaned out so that the CO really is low (1-2%?) then apparently the HC from combustion should also be very low. I've got a graph at work which I'll try and post tomorrow. If that's the case and your engine is, what you could say, of mature condition then maybe it is oil being sucked past the valve seals and rings. A compression test would show this.
    However aren't there lots of 'miracle' coating liquids on the market that promise to help in these cases? Anybody got experience of these? It may be a fix for the test.
  8. tomoshea
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    OK Guys,
    Here are the facts, this car is a SINGLE DISTRIBUTOR NON CAT Euro car.
    The Carbs are at about 3% CO and 1400 PPM HC's.
    If I drop the CO lower say 1% then the HC's rise up to about 1850 PPM which indicates to me the burn is not completing in the cylinder.
    If the car is a non Cat car will adjusting the timing do anything?
    Secondly I am interested in knowing if there are any treatments/ additives/ coatings that will drop the HC's even temporarily?
    I have also head that doing a complete oil flush and refill will help, but I want to get as much advice as I can before I do anything.
    I want the belt, the braces and the string all combined before I put this through a test.
    Hope that will help you guys wuth your recommendations
  9. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Specifically, the goal of retarding timing FOR YOU would be to benefit from the post-flame oxidation, sorry if I wasn't clear.
  10. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I'm not expert at this but I'm wondering...since you are SO close to the number needed to pass emissions, will different spark plugs or a hotter set of coils increase the burn just a little to get the HC down?
    I'm amazed that such an old car needs to pass emissions in a country that didn't even require catalytic converters until about 15 years ago!
    Birdman
  11. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    In the US there are some high oxygen additives that can be used to get emissions down temporarily. Search the archives (probably the old ones) for 'emissions'. There are several very long threads that have many good tips.
    Believe it's primarily alcohol, but could have another high oxygen compound. A couple of bottles in 1/2 or 1/4 tank should do the trick along with tweaking your timing.
    I can't remember specific brands, but they're out there. If you can't find it in the UK, ask & we'll get you some.
  12. F40
    F40 F1 Rookie
    Apr 16, 2003
    3,230
    AZ
    Rubbing alcohol is your friend :)
  13. 208 GT4
    208 GT4 Formula 3
    Dec 27, 2003
    1,769
    Brighton (UK)
    Dan
    My advice would be to take your car to a different MOT station.
    Some of them are so used to modern cars, that they don't know how to get an older vehicle through the emissions test. The one I use is prepared to adjust the revs in order to get a good reading. It would fail at idle, but at 2000rpm it passes...while still falling within the range of revs allowed for "idling".
  14. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    A too lean condition will often produce poor burn and high HC. A lot of Porsche guys here convert to Webers and keep going leaner because of the black smoke and hesitation, not realising that te opposite is required. try setting the CO about 4.0-4.5% and see difference. Also the retard a few degrees will also help. you may actually notice a better bottom end respose.
    Cheers, Brian
    relocated Brit.
  15. tomoshea
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    Thanks Guys for all your help I will search the archive for the fuel additives to improve the burn and if I cannot find anything I will get back to you!
  16. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
  17. mikeg
    mikeg Rookie
    Nov 3, 2003
    24
    There is this stuff called "guaranteed to pass" for sale at the local parts store. i haven't needed to use it, they guarantee it to bring your numbers to a passable level.
    Also, make sure that the car in realy warmed up, a good half hour before testing!!!
    good luck
    Mike G
  18. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    I talked to Mike at Pierce who has a (79) 308. Runs it with 52 idle jets. Passed emissions w/o the airpumps. If it will pass in CA, it'll pass in the UK.
    As others have said, take some timing out at idle. See where that gets you.
    Philip
  19. 4i2fly
    4i2fly Formula 3
    Apr 16, 2004
    1,333
    SF, Bay Area
    I agree with the above and also suggest 100 octane racing fuel from union 76, it can help reduce emissions for smog test.
  20. RF128706
    RF128706 Formula Junior
    Apr 8, 2004
    280
    208 GT4 is right on the money with his suggestion. You need to find the right MOT centre, don't fudge the engine until it's absolutely your very last resort. You run the risk of running lean & damaging something (like a valve or piston) or getting the exhaust system so hot through spark retard you end up with a secondary failure somewhere else (like a burnt-out exhaust valve). If the car is running nicely leave it. Look in Classic Car Weekly for a morris minor/MG/Triumph specialist that does MOTs & take it there. They will know exactly how to "handle" classic cars.
    Try this site, it may help you, you may not be doing the correct MOT procedure:
    http://www.motuk.co.uk/manual_730.htm
    And one last thing -- are you sure your particulate meter is accurate ? Just a thought...
    Rob.
