How can I trace fuel smell. | FerrariChat
Discussion in '308/328' started by bertspeed, Oct 3, 2015.
  1. bertspeed
    bertspeed Formula Junior
    Sep 19, 2009
    308
    I have a euro carb gtb and notice after a drive I feel kind of intoxicated and there seems to be some kind fumes in the general area.Its not a strong fuel smell but could be fuel or exhaust vapours.A general look at the fuel lines seem ok but without replacing anything that might be suspect I would like to trace the exact source first.Is there a proeedure to do this.
  2. mwr4440
    58,098
    Bavaria, The 'Other' Germany
    Mark W.R.
    Try a cigarette lighter.
    When it goes "Boom!" you've found it. :D
    Seriously though, good question.
  3. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,665
    Avvocato
    Two years ago I can across a similar situation. Once I parked the car for the winter season I checked the lines visually and couldn't find anything. This spring season when I fired her up, the smell got stronger - took her for a small drive around the neighbourhood and let it sit in my driveway for a while running. It was then I noticed one of the fuel lines being damp.
    Seems it maybe time to do your fuel lines - change all if them, don't just change just the culprit.
  4. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Is it gas or exhaust. Have you check to see if any of the carbs are leaking or are wet on the outside. Do you smell gas several minutes after you shut down the car. Is your vapor recovery system in tact. Are all gas lines dry. Check exhaust for leaks. Look at sample port tubes to make sure they are not cracked or rusted out.
  5. Patrick Dixon
    Patrick Dixon Formula 3
    Mar 27, 2012
    1,138
    The fuel tanks leak as well, so check those carefully.
  6. 4right
    4right F1 Rookie
    #6 4right, Oct 3, 2015
    I had the same issue a few years ago. I traced it back to the part/union in this picture that connects the three fuel lines together. It had developed a crack which allowed gas fumes to buildup in the garage.
  7. dinogt4guy
    dinogt4guy F1 Rookie
    Oct 31, 2004
    3,411
    Hewitt, Tx.
    Kurtis Fordice
    I have a similar issue too, found it to be the hoses that connect the 2 tanks below. Ordering a new set from SRI Monday when he returns from out of town.
  8. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #8 Wade, Oct 3, 2015
  9. bertspeed
    Sep 19, 2009
    308
    Thanks for the replies.In answer the fuel lines seem dry on the outside,but the carbs have alot of staining on the outside but I think thats normal for a 35 year old car.The smell lingers on for a good half hour after the drive,but is not there when the car is not used.ve.The sniffer looks good,I will try and get hold of one.I will also replace the fuel lines but want to trace the problem first.
  10. greg 19425
    greg 19425 Formula 3
    Jan 6, 2011
    2,471
    Wake Forest, NC
    Greg
    Change the fuel lines, the new gas just eats the old lines like a Thanksgiving dinner. Takes about a day, but well worth it. :)
  11. ClydeM
    ClydeM F1 World Champ
    12,100
    Wayne, NJ
    Clyde E. McMurdy
    Let me offer my .02 cents: What changed?
    if you haven't done a major or gas filter change or messed with any hoses, then I'd say some fuel line cracked somewhere or fuel pump or accumulator is showing its age.
    In my case, it was a major about a year ago and all hoses were replaced. Hence it was more likely a hose clamp was loose. And so it was, the vent hoses on the top of the right fuel tank didn't last.
  12. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    The gas in the float bowls will evaporate, especially when your car is hot just after a drive. My car has a flapper on air box that closes when hot and off. It makes a noise when I turn the car off as it closes.
    Does your car have that?
  13. mwr4440
    58,098
    Mark W.R.
    If one has an FI car, change ALL the plastic lines too. All. Of. Them.
    Just because they "look good" doesn't mean squat. Don't bother asking how I know.
    A member here makes a good kit to do the job. And it ain't expensive. No affiliation.
  14. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,693
    Sarasota
    David
    My Carb 308 has a stronger smell when I use gas with ethanol which is more prone to evaporation.
  15. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,288
    Black Forest Germany
    Martin N.
    It's a Euro carb car without any vapour recovery system or similar things. Or without flaps in the airfilter box.
    Like scowman already mentioned, it just has four carburettors in the middle of the engine V filled with fuel which heats up after a drive. Just sniff on the passenger side intake and you will smell where the fumes come from.
    I fear you will have to live with that with a Euro carb car.
    Best Regards from Germany
    Martin
  16. 4right
    4right F1 Rookie
    All carb 308s tend to smell of gas when park in a contained unventilated space. 40 years on, I would have to assume that even with cars equipped with the flaps on the air box, they probably aren't working as designed anymore anyway. Is this a new car to the OP? Otherwise something has changed that is causing the more pronounced fumes.
  17. BigTex
    79,407
    Houston, Texas
    Bubba
    Refill/renew, or replace the charcoal canister, that vents to atmosphere.
