How cold do you still drive your Ferrari before storing it for winter? | Page 2 | FerrariChat
Discussion in '348/355' started by Franc, Nov 6, 2009.
  1. Timmo
    Timmo Formula Junior
    Aug 26, 2017
    731
    Continental Europe
    In similar weather I see similar temps in mine, cruising below 3000 rpm in 6th gear. That's normal.
    308 GTB and IvanRico like this.
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Definitely cooler water temps for sure.
  3. bball16
    bball16 F1 Rookie
    4,165
    NY LI FtL
    After a few miles all temps are normal. Just have to go easy til tires heat up.
    IvanRico likes this.
  4. IvanRico
    IvanRico Karting
    198
    Westchester NY
    Ivan Rico
    True. I did notice that the water temps did slowly warm up to almost normal operating temps over time on the highway. Probably only 10 deg F off normal, eventually.
    And yes, the Michelin PS4S tires are pretty great even in freezing temps. Best summer street tires I've used. Still, I try hard to put 90% of my winter miles on true winter tires in a car/SUV with all the modern safety equipment. I do like challenges and adventures, but black ice or damp 33 degree roads are risky in a 28 year old car nevermind one with the wrong tires.
    308 GTB likes this.
  5. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    All gauge readings were where they should be under the conditions in which you were driving, Ivan.
    Thermostats are inexpensive. There's nothing wrong with changing it at your engine-out but it's good practice to test the new one before it goes in.
  6. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    As an aside, my Challenge car's engine cooling system is still set up as it was when it raced. Challenge regulations mandated that both fans be on when the car was on the track.
    My car has separate toggle switches to turn the fans on and off...
    The shielded switch is the master ignition switch.
  7. tbakowsky
    Sep 18, 2002
    20,077
    The Cold North
    Tom
    Cold and snow is not gonna hurt your car. The salt and sand will.
