News
How cold is too cold
Discussion in '348/355' started by Novice, Mar 22, 2009.
  1. Novice
    Novice Rookie
    Apr 30, 2008
    16
    ROCHESTER NY
    It's been a long cold winter and the 348, I'm happy to say, has made it through like a champ (oil change, tarp on the floor of the garage and tires off the ground), she started right up yesterday. As I was driving her today (41 F and sunny) everything was perfect, though at high speeds the oil and engine temp were a little lower than in summer. My question is, what temperature is too cold? When is it ill advised to take the car out and get her hot only to put it in a below zero garage for the night?
  3. DerWebMeister
    Aug 21, 2007
    119
    Columbus, OH
    Timothy
    Hi, for the most part, engines like colder weather. I think it would always be smart to get the engine running as often as weather permits. Sometimes the weather is sunny but the roads are still salty or being sprayed with sodium bromide. Of course you'll make sure the roads are clear. I think getting it hot and running is a smart thing to do.
  4. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie
    4,222
    90210
    Kevin
    I've run mine as low as 20 F(f355)
  5. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,548
    TX
    Sameer
    Same here - mid 20s without a problem. Just give the car some additional time to warm up. And watch out for black ice.
  6. dlynes
    dlynes Formula 3
    Oct 16, 2004
    2,428
    Augusta, Ga
    Dave
    as stated, engine run better with cooler weather/temperatures unless it is extremely below 0*F.
    As long as you allow plenty of time for your engine to warm up, driving in COOL weather is great just keep in mind, running the heater cools the engine off even more
  8. Neonzapper
    Neonzapper F1 Rookie
    Oct 19, 2008
    2,531
    MD/FL/Philippines
    Mykol
    I run mine at least once a week regardless of temperature, but not in foul weather. It runs fine in cold weather, and I've had it out in the 20's too, but admittedly it started out in the warm garage and ended up there, too.
  9. conscom
    conscom Formula Junior
    Jan 6, 2008
    467
    Vancouver BC Canada
    Gary
    I drive my all year, whenever roads are dry. Just give more time to warm up and drive easy until water and oil temp. up to normal. Runs great in cold weather.
  10. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,213
    Palos Verdes
    Vince V
    Should be fine in most conditions. Make sure that your oil temp is rising off the peg before you drive and do not red line the thing until you are properly warmed up!
