430 - How connect a trickle charger behind drivers seat? | FerrariChat
430 How connect a trickle charger behind drivers seat?
Discussion in '360/430' started by biro, Apr 14, 2019.
  1. biro
    biro Rookie
    Feb 23, 2019
    11
    Hi,
    I currently have a trickle charger cable connected directly to the battery under the passenger side foot well but would like to connect a new trickle charger to the connections behind the drivers seat as this location would work better for me.
    Would appreciate advice on where to connect it too (pics are welcome :) and in what sequence to do things as I'm pretty inexperienced with electricity in general and want to avoid damages to the car or myself.
    Any advice on trickle charger by the way? I was thinking of a CTEK MXS 5.0 but am open to suggestions.
    Big thanks in advance.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Just remove the cover behind the seat and look for the big heavy red cable, connect your positive to it. Look for a bolt holding a bracket to the body for the negative black wire.
    A lot of people like the ctek but it can be a bit fussy, in that it can lock it self out if it thinks you have a battery fault. I use another make but i have mine on a daily timer for 1 hour a day and that works fine. The ctek has left me with a flat battery a few times for no reason.
    Sj_engr, RedTaxi and whatheheck like this.
  3. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Just want to add that you may have experienced a defective CTEK. I have several 7002 CTEKs and none has ever left me with a flat battery. I’m not sure what you mean by “lock itself out.” If you mean turn itself off, I think there are safety circuits in it that could do that if there is a wiring or other electrical fault in your wiring. You may have a fault in your wiring or a defective CTEK.
    cpep likes this.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    A lot of people like them but i prefer to have a charger on a timer, stops it putting a trickle charge in over the winter and sulfating the battery plates.
    Cars in the uk are fitted with trackers which loads the battery , my timer gives it a bit more than a trickle daily which is no bad thing. Had 2 ctek 5.0 and flat batteries, no problem with my present setup. This works and is reliable and you are probably right about protection circuits, but i think over kill comes to mind.
    The ctek gave me a flat battery and i could not get into the car with the key. Could not get the doors open- had to jack the car up , remove a floor section and charge the battery via the starter cables. Not a mistake i will do again
    f355spider likes this.
  5. f355spider
    f355spider F1 World Champ
    18,045
    Many newer battery tenders have modes to prevent sulfation, and even have desulfation modes. BTW, I have no problem with your using a timer if you don't trust the microprocessor to prevent overcharging, that is good insurance. One idea I saw a friend do, was to take one of the lightbulbs out of his garage door opener and install a plug adapter. He plugged his battery tender into it for his Ferrari. Since the opener opened two doors and the other bay had his daily driver, his Ferrari automatically received at least two 5 minute trickle charges each day, sometimes more if he had errands to run. Clever.
  6. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I'm 360 Canuck and f355spider like this.
  7. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    Another vote for Mike32. That's how I did my 360. I have attached to the battery in my 430 and it is more awkward to connect the charger. I might do the behind the seat connection again. C-tek 3.8 amp working fine for 6 years now.
  8. f355spider
    18,045
    At what year of manufacture did Ferrari add the battery charger connection under the passenger dash? I know my 2009 430 Scuderia has this.
  9. oc23
    oc23 Formula Junior
    459
    Rob Yo
    To anyone who may know - does it matter which one of the three bolts you connect your positive to under the + cover? I could not get the right one loose, so I connected mine to the middle one. CTEK seems to be charging so I'm guessing that's fine but wanted to make sure.
  10. Qavion
    Qavion F1 World Champ
    14,312
    Ian Riddell
    Not really (as long as all are secure). One sounds more than secure :p
    oc23 likes this.
  11. houtie123
    houtie123 Formula Junior
    Dec 9, 2007
    548
    Cape Town, RSA
    Andrew
    My 430 had a build date of sep 07 and has it
  12. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,621
    San Jose
    dc
    Should be able to add tap-a-fuse and enable to "no start" similar to the OEM charger also.
  13. sfcarguy
    sfcarguy Formula Junior
    527
    Earth
    They added it late in MY07. All MY08 and MY09 have it as far as I'm aware.
    houtie123 and f355spider like this.
