How did you hardwire your radar detector to your car? | FerrariChat
Discussion in '360/430' started by fstbiker, Aug 5, 2013.
  1. fstbiker
    fstbiker Formula Junior
    Jun 28, 2012
    509
    New Jersey
    How did you run it and what fuse box did you use and fuse location? Im running a valentine one and want to get rid of the cigarette hook up for a cleaner look in my 430. If you have photos that would be great.
  2. bobp
    bobp Karting
    Jul 21, 2011
    80
    New Orleans
    Bob
    The easiest way by far is with the OBD connector sold by Valentine. It snaps onto the OBD plug just under the dash on the right of the steering wheel. Run telephone wire through gap at top of winshield and winshield frame, down left A-pillar under the rubber seal then to under the dash. 2 pull ties to clean up any wire hanging down under the dash. Totally invisible and takes all of 20 minutes- all of that is used to make sure the wires are all hidden correctly.
    The V-1 goes on with ignition.
    caveat- if you hook your car up to a battery tender it feeds the V-1 , and after you disconnect to go for a drive the V-1 will stay on the next time you turn the ignition off for some reason. Just unplug-replug the OBD adapter( you can do it blindly- dont have to crawl under the dash) and the V-1 will go to off until ignition starts it again.
    Its really easy so try it and good luck.
  3. plastique999
    plastique999 F1 Veteran
    Nov 9, 2008
    8,841
    SoCal
    Edward
    Is there a similar OBD connector for the Escort? Would like to hardware this as well
  4. wahoo5
    wahoo5 Karting
    Nov 9, 2009
    182
    Richmond, VA
    David
    Thanks. I had not figured out why my V1 was not turning on and off wth the ignition. This is the answer.
  5. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,449
    On the Limit
    Dino
    I ran the hardwire from the visor through the A pillar trim. I then found a wire that was 'hot' under the dash and tapped into it. 20 minutes..... done!
  6. fstbiker
    Jun 28, 2012
    509
    New Jersey
    Any way you can take a picture if the connection
  7. S Brake
    S Brake F1 World Champ
    Aug 3, 2006
    17,182
    Utah
    Dave
    While not a Ferrari, I tapped into the map lights on my 4Runner and mounted it to the rear view mirror using a blend mount. Took maybe 15 minutes to do and works great.
  8. plastique999
    Nov 9, 2008
    8,841
    SoCal
    Edward
    I think this is what I'm going to do...
  9. Stevely
    Stevely Formula Junior
    Jul 21, 2011
    634
    LA, CA
    #10 Stevely, Aug 6, 2013
    What do mean by tapped into? Splicing and soldering onto the existing map light wire?
  10. S Brake
    Aug 3, 2006
    17,182
    Utah
    Dave
    I bought a kit from eBay that makes it really easy. I ordered it with the t-tap rather than the fuse tap so I could pull power from the map lights. The t-tap makes it so you don't have to splice and solder anything. Just clamp the tap down and ground the wire and you're done.
    http://www.safe-n-sound1.com/Valentine%20DC%20WF.html
  11. fstbiker
    Jun 28, 2012
    509
    New Jersey
    #12 fstbiker, Aug 23, 2013
    SonnyCrocket likes this.
  12. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,732
    Just East of Weird
    Bob
    Like it, congrats! I think I'll move my remote, I like it your way better!
  13. fstbiker
    Jun 28, 2012
    509
    New Jersey
    Just use the same aluminum piece as the rear. Bent it, painted black and added some Velcro.
  14. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    #15 Jeff Pintler, Aug 27, 2013
    I hard wired to power connection on the clock unit above the mirror. There is switched power and ground wires. I also made a metal bracket that mounts under the driver visor "C" clip. Another way is to use the unit in front of the clock pod using the suction cups on the glass. And then use the remote display unit down on the console. It kinda looks clunky but it tucks behind the visor mount and the driver can view the display very well. The display is not visable from the rear window. I also upgraded the dome lamp from the 640 ma. bulb to a LED that outputs a whiter color and draws 120 ma. Good Luck!
    Jeff Pintler
    89 348tb, 86tr, 99 360 3-pedal
  15. matbo911
    matbo911 Rookie
    Mar 2, 2011
    1
    #16 matbo911, Dec 3, 2013
    I used the radar-mirror, and installed the V1 above the courtesy lights ... they guy who runs the small operation in Dallas (Scott Wheeler) sent me a mirror with the display, and for $50 added Homelink. The 430 mirror was also used on an older BMW 7 series, so it doesn't cost Ferrari prices. I love the install, unfortunately, I now have a 458 on order, and there isn't enough room above the mirror/courtesy lights, he's gone to a behind the bumper install, which seems less than optimal.
