How do I adjusted the engine hood latch | FerrariChat
Discussion in 'Boxers/TR/M' started by mr308gtb, Nov 1, 2020.
  1. mr308gtb
    mr308gtb Formula Junior
    Sep 12, 2004
    702
    MeestahBig
    Hi -
    on my new 1989 U.S. testarossa, I cant get the engine hood to lock in. It closes, and lays flat, but it wont lock into the latches. when I observe the latches with the hood up, they appear to be in good shape and fine, I can push down with my hand and they click lock in, then I can release them with the cable lever in the car or just push on the rod and pop open... but no luck when trying to push the hood down into the mechanism.
    Thanks.
  2. fridolin_pt
    fridolin_pt Karting
    Mar 25, 2008
    162
    Germany NRW
    Fritz
    A common problem. Needs adjustment of the mechanism.
  3. mr308gtb
    Sep 12, 2004
    702
    MeestahBig
    Ok, any details or wrtieups.on how to adjust it? Thank you
  4. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    Usually- on mine, had to do one corner at the time. Gentle on the pressure with both hands on one side and then did the other one.
  5. mr308gtb
    Sep 12, 2004
    702
    MeestahBig
    I am not a light guy, I put a lot of pressure onto it to push it down, just wont lock in, which theory does seem off.
  6. Steve Magnusson
    26,764
    #6 Steve Magnusson, Nov 2, 2020
    It is not rocket science. Just loosen the two bolt/nuts holding each latch and then move them up slightly to help them better capture the wire form piece on the underside of the engine bonnet. The only tricky bit is you only want to move them up -- not fore-aft so might be helpful to do something like marking the fore-aft position with some masking tape before loosening the bolts/nuts to know were they were fore-aft (there's a lot of slop in the holes that the bolts pass thru):
    PS Ignore the wooden stick in the photo -- that's related to opening the rear latches thru the rear grill if the release cables are broken.
  7. Natkingcolebasket69
    U should write a book! Ur pics and
    Legend are always so detailed and thorough!
    ago car nut, vincenzo and turbo-joe like this.
  8. mr308gtb
    Sep 12, 2004
    702
    MeestahBig
    Thank you Steve...
  9. W0waxni
    W0waxni Rookie
    Sep 26, 2024
    1
    Wally Wazni
    #9 W0waxni, Jan 17, 2025
    How do u adjust the cones. The right side of my hood is maybe 2mm higher I see a bolt underneath the cone after that is loosens do u with the cone or just it just slide
  10. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,524
    romano schwabel
    remove the latch both sides completely and adjust first the cones that the hood is equal with the other parts. then put in again the latches and adjust
  11. Steve Magnusson
    26,764
    I believe the nut is just a locknut, and the conical bumper has a threaded shaft and threads up and down for height adjustment (and then the locknut is tightened to hold it in that position) -- but I no longer have TR to check that.
    ago car nut likes this.
