How do I check the brake fluid level in my 360 ? | FerrariChat
Discussion in '360/430' started by balenciaga, Jul 17, 2009.
  1. balenciaga
    balenciaga Formula Junior
    383
    NYC
    derek
    thanks Derek
  2. Skidkid
    Skidkid F1 Veteran
    9,650
    Campbell, CA
    John Zornes
    Remove the panel behind the trunk, yes you have to open the trunk to see the 3 screws. You will see the brake fluid reservoir there and there is a max fill line.
  3. Derek Trotter
    Derek Trotter Formula 3
    1,790
    Cambridge, UK
    As SkidKid says, the panel is next to the pollen/cabin filter.
  4. Skidkid
    Skidkid F1 Veteran
    9,650
    Campbell, CA
    John Zornes
    #4 Skidkid, Jul 17, 2009
    I took this when I was doing the alarm siren battery so the trunk liner is out but you can see the brake reservoir and the pollen filter. You can easily work out the cover from there. It has the yellow cap.
  5. balenciaga
    383
    NYC
    derek
    cool thanks so much.
